Old 08-07-2007, 04:09 PM   #1
Car: 01 Subaru WRX STi Sp
Default StreetTUNER Advanced is now available...
StreetTUNER Advanced is available! The StreetTUNER Advanced software is $395 for the full version. This full version will come on a CDROM and a HASP key will be shipped with the software.
If you purchased the original StreetTUNER for the original price of $400 then you will be able to get a StreetTUNER Advanced CD shipped to you for free. You will need to call in (801) 713-0035 and speak with one of representatives as well as have proof of purchase of the original StreetTUNER at the original price to have the free CD shipped to you.
If you purchased the StreetTUNER software at the discounted price of $195. Then you have the option to purchase StreetTUNER Advanced for and additional $200. You will need to call in (801) 713-0035 and speak with one of representatives as well as have proof of purchase of the original StreetTUNER at the discounted price. You will then be charged the upgrade price of $200 and a CDROM with StreetTUNER Advanced upgrade will be shipped to you.
StreetTUNER Advanced gives you access to all ECU tables that are currently available in the Professional AccessTUNER software. One of the new features allows you to install our MAP sensor adapter and then calibrate the ECU so a 3.5 Bar MAP sensor will work with the stock ECU. By calibrating the ECU tables for this new sensor and using the sensor adapter you will be able to tune up to 35psi (relative) of boost pressure using the stock ECM!
The use of the MAF sensor for more precise fueling and ignition advance calculations is still kept in tact! This should allow the stock ECU to read up to 50 PSIa which will allow you to use the stock ECU tables to calibrate up to 35 psi of relative boost pressure using all other stock hardware. The AccessTUNER software should also allow you to read, display, and log these higher values using the stock ECM. We have tested the Zeitronix 3.5 BAR MAP sensor and the AEM 3.5 BAR MAP sensor (AEM Part # 30-2130-50). The Zeitronix 3.5 BAR MAP sensor shows some better specifications, should perform more consistently, and is less expensive than the AEM unit...but either should work. We are offering two adapters that should fit all USDM Subarus, see below product pictures.
Part # SUB00021
For Subaru WRX, STi, & FXT that has the stock MAP sensor installed in the throttle body assembly.
Part # SUB00020
For Subaru LGT & FXT that has the stock MAP sensor installed on the intake manifold.
These adapters retail price is $50.00 each, and both of these adapters are available now. The part # SUB00020 is for the Legacy GT 2.5L 4-cylinder Turbo and the modern 6-cylinder Throttle-By-Wire vehicles. The part # SUB00021 is for all other Subaru 4-cylinder Turbos and the older 6-cylinder vehicles. You will need to carefully remove and re-use the stock MAP sensor O-ring with the use of the SUB00021 adapters in order to make a proper seal. We are not going to carry the 3.5 BAR MAP sensors so you will need to purchase them directly from the above two links or through their perspective dealer networks.
Take care,
Christian.
Christian. is offline   Reply With Quote
Old 08-07-2007, 04:28 PM   #2
Fav Mod: sz55 external wastegate
Default Re: StreetTUNER Advanced is now available...
Yea I saw info about the release on Cobbforums also but have yet to find info on exactly what tables are accessable to us with this update. What tables and features does ProTuner have that we didnt have access to?
Mycues1982 is offline   Reply With Quote
Old 08-07-2007, 05:29 PM   #3
Awesome news
Old 08-07-2007, 05:31 PM   #4
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
So I heard on your Forums.
Im super stoked.
Old 08-07-2007, 06:17 PM   #5
Fav Mod: Synapse FMIC
Very nice! What about the TXS 5 BAR map sensor?
jays05 is online now   Reply With Quote
Old 08-07-2007, 06:32 PM   #6
FWIW, I've been using the Cobb adapter and the Zeitronix 3.5 bar sensor for a while now. Works perfectly.
Old 08-07-2007, 07:20 PM   #7
This is very difficult to explain since all ECUs have different tables, the updated table list would be huge since this would account for 21+ different ECUs. We have received requests in the past for access to various tables by our Professional AccessTUNER network...which basically means that StreetTUNER Advanced gives you access to all tables currently available in the Professional version of our software.
We should be able to calibrate to that MAP sensor perfectly fine. We specifically made the MAP sensor adapter so it would work with any 1/8th NPT MAP sensor. I would be happy to work with you to establish the calibration values. I have verified that the boost control values can be set that high in the ECU...so nothing would be stopping us. With that said, have you ever driven on a 5 Bar MAP sensor...on speed density set-ups they street driveability is not that good but you should be fine using the MAF sensor since the MAP sensor values are mainly used for compensatory values and boost control. Please PM me if you are interested in working on a 5 BAR calibration.
Take care,
Christian.
Old 08-13-2007, 05:07 PM   #8
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
Got it installed today.
Here is a screenshot of the table list for ST Adv Ver 1.5.0.7 for a 2005 STi.
Old 08-13-2007, 05:36 PM   #9
Thanks for posting that
Old 08-14-2007, 11:36 AM   #10
Car: '05 STi
Fav Mod: Cusco Zero 2R's
Got my disk. Loaded it. No problem until I try to communicate with the vehicle. It does not see the ECU. Had no issues ever with the prior version.
Christian- any suggestions?
Thanks
04stiguy is offline   Reply With Quote
Old 08-14-2007, 11:54 AM   #11
Thanks
Yes, the software can actually tell you why it is not able to connect to the vehicle. If you go to the "Help" drop down menu in the StreetTUNER software, then select View Log File, a .txt document will pop up telling you why the software could not connect. Read what that says and you can diagnose from there.
Take care,
Christian.
Old 08-14-2007, 12:09 PM   #12
Car: '08 WRB SG Model D
Fav Mod: All of them...
Christian,
Make me an AP v.2 w/ StreetTuner advanced software for my '08 FSXT and I will buy it.
-Will
sirwilliam is offline   Reply With Quote
Old 08-14-2007, 12:09 PM   #13
Does the update require you to update your AccessPort in any way? My AP cable is mangled, I've been using a tactrix cable w/streettuner for the last year or so.
Old 08-14-2007, 12:19 PM   #14
Car: 05 CGM FXT
What? That works!?? My AP cable has been going crazy. It works only about 75% of the time. I'm just going to use the tactrix cable form now on then!
ZuMBLe is offline   Reply With Quote
Old 08-14-2007, 01:33 PM   #15
The install will want to talk to the AP but you use a NULL modem serial cable for that. Not the OBDII port cable.
