Old 07-02-2007, 11:50 AM   #1
Car: 06 STI Steel Gray
Fav Mod: SS Stage 2+ Tune
Default Cel 0420
I have an 06 STI that has a MaddDad catted TBE and Cobb Street Tuner. I have been running a Stage2+ map and I have begun to throw CEL 0420 after about 3 months with no issues running a custom map. Has anyone run into anything similar in the past?
06STIMan,
This is the Stage 2 plus map I got from you. Have you seen the CEL 0420?
warfare is offline   Reply With Quote
Old 07-05-2007, 01:53 PM   #2
Car: 05 STI
Default Re: Cel 0420
it is the obdII code im pretty sure
1slwsti is offline   Reply With Quote
Old 07-05-2007, 04:33 PM   #3
Check your map to see if you have that code enabled. Sounds like the cat-related CEL which is normally turned off when using StreetTuner.
Old 07-05-2007, 04:50 PM   #4
STI Guru
Fav Mod: Whooshing sounds
06STIMan,
That's the code for Catalyst efficiency. Mostly found in catless DP's, but you're catted.
I believe you can defeat this problem with the StreetTuner, see following link:
http://www.cobbforums.com/forums/showthread.php?t=33252
Old 07-10-2007, 05:31 AM   #5
Thanks for getting my head back on straight guys. I checked the codes and in the OTS Cobb Stage 2 map has 0137, 0138, 0139, 0420 disabled. I changed my map and reflashed. I have not seen any codes yet. Thanks!
These codes are all Cat related.
0137 - Oxygen Sensor Circuit Slow Response
0138 - Pre-Catalyst O2S Shorted to Voltage
0139 - Oxygen Sensor Circuit Slow Response
0420 - Catalyst System Efficiency Below Threshold
Old 12-02-2007, 07:06 PM   #6
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
although this code is disabled with stage 2 if you are catted you should have no problems with this code. at the same time your aftermarket downpipe has a not so high quality cat in it so that probably the issue. you should just gut that **** out and go catless then.
Old 12-02-2007, 07:16 PM   #7
A.X.D.
Car: 2004 STi
Big Problem......help
