Old 06-09-2007, 08:25 PM   #1
Question Problem with my Dynamic Advance Table
Hi,
I am new to Streettuner. My current map was originally done by a protuner, and saved as streettuner format.
With ST, when I view the Dynamic Advance Table A, B & C.
Both A & B are fine.
But My C Table have rpm listed from top to bottom being all 0RPM except for the last line at 7200rpm.
eg
0
0
0
0
0
0
0
0
0
7200
Is there a way I can make all those 0 back to normal rpm??
Thanks
EL
Old 06-10-2007, 04:49 AM   #2
Moderator & ECU Tech
Fav Mod: mo boostaz
Default Re: Problem with my Dynamic Advance Table
Highlight and copy the RPMs from DA A or DA B and then paste into DA C. Save the File.
Did you notice this when simply viewing your file offline or did you notice it after you connected to the ECU????
t
Old 06-10-2007, 03:48 PM   #3
Update:
I connect the laptop with Live tuning, and end up copy from the Cobb street tuner stage 2 DA C to my street tuner map.
Thanks for your tips! Looks like the next thing that I gonna do is get some logging!
EL
I notice this as I am reviewing the file! But I gonna go outside and hook it up as real time tuning in now!
Thanks
EL
t
