Old 05-25-2007, 04:51 PM   #1
Car: 07 UGM STI w/Gold BB
Fav Mod: The Drift Angle!!!
Default Can boost control be used?
Can Cobb control a Perrin type boost controller?
Thanks,
Matt
torqueflight is offline   Reply With Quote
Old 05-26-2007, 06:28 AM   #2
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
Default Re: Can boost control be used?
You are really asking if the factory ECU (hardware) can control boost by sending signals to the perrin solenoid. Yes it can. Cobb accessport/streettuner/accessecu stuff just changes the parameters the factory ECU uses. You will need to use parameters that are different from stock.
