Old 05-13-2007, 01:23 PM   #1
Car: 05 RS with the hart
Fav Mod: EJ 257 + PPG Dog Box
Default rev limit
so i was messing around the other day and noticed that the AP or ST has the rev limiter set to 7000, i thought that the stock STi ecu rev limit was 7200? what do you guys set your limiter to? the bump in rpm could be worth 1 or 2 mph in the 1/4...
Denali is offline   Reply With Quote
Old 05-25-2007, 07:41 AM   #2
Default Re: rev limit
I have gone as high as 7800, but I have a bit lighter piston and pin combo than stock. Even at 7800 I can not get through the traps in 4th gear, it still bounces off the limiter before the traps.
IMO 7500 should be the absoulte max you should spin the STOCK lowwer end.
TMS
TheMadScientist is offline   Reply With Quote
