Old 04-21-2007, 10:30 PM   #1
Exclamation Help Can Streettuner use str file from Protune
Hi Everyone,
I recently have my 06 STi Protune. The tuner was able to give me both the protune base/real maps and street tune base/real map. Currently, with my access port, I can only load the protuner .ptr & .ptb files. But if I would to buy the street tuner software, would I be able to use the street tuner maps which are saved by my pro tuner?? So, that I can learn to fine tune the existing professinoallytuned map.
Thanks
EL
Old 04-22-2007, 06:00 AM   #2
Moderator & ECU Tech
Fav Mod: mo boostaz
Default Re: Help Can Streettuner use str file from Protune
Yes.
t
Old 04-22-2007, 02:51 PM   #3
Thanks! I'll probably order my streettuner software today!
EL
Old 04-23-2007, 05:27 PM   #4
so if you where Protune you can download that and open it or do you need a ST file from your tuner?
TraSTi is offline   Reply With Quote
Old 04-24-2007, 03:11 AM   #5
Fav Mod: mo boostaz
You need a StreetTUNER file from your tuner. Guys like Christian from Cobb, when you tune your car, they also give you the StreetTUNER version of the files in case you ever decide that you want to start using StreetTUNER.
t
Old 04-25-2007, 05:21 AM   #6
ok THANKS!!!
