Old 03-09-2007, 04:00 PM   #61
Car: 07 335
Fav Mod: NOISE
Did you check the knock learning table?. I know there's a post by Wolf about this problem here ECU timing = ??
Anyway goodluck.
STLSTI is offline   Reply With Quote
Old 03-09-2007, 04:14 PM   #62
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Anyway goodluck.
I was reading that thread as you posted.
0's in throughout the whole Knock learning table..
Old 03-11-2007, 03:48 PM   #63
Enginerd
Fav Mod: Tuning
Now the problem is back but only happens in 5-6 gears....really weird...
I hit the same load numbers in gears 5-6 as in 4th gear but it doesnt pull any timing from DA in 4th gear....?
Old 03-11-2007, 05:02 PM   #64
Car: Slow 05 STi
Fav Mod: Loping Idle
Trader Rating: (12)
Logs? You may need to rescale your tables more because you are more likely to hit higher loads in those taller gears. 5th and 6th gear are the hardest to tune b/c of the way the react when you hard load the car. Almost always you will overshoot your boost targets and thats when tuning the turbo dynamics becomes a huge factor.
