Old 03-01-2007, 05:21 AM   #31
Moderator & ECU Tech
Fav Mod: mo boostaz
Are you sure you aren't talking about what has been covered previously?
Start at post #8
http://www.iwsti.com/forums/showthread.php?p=870392
t
Old 03-01-2007, 12:50 PM   #32
Car: 06 Evo IX SE
Start at post #8
t
Yeah, he's definitely got a different issue. His DA values are actually showing up in the log less than his targets specified in the map table (i.e., getting 8.5 in the log vs. 10 in his map). The issue in your link relates to total timing not equaling target timing when the DA is logged at max value.
06stiman is offline   Reply With Quote
Old 03-01-2007, 02:57 PM   #33
Car: 07 335
Fav Mod: NOISE
Originally Posted by crystal_Imprezav
Lower all the timing at about 1-1.9 load. These are the load points where you are spool.
It works, I change my PI from 2k to 3k and from 1.0 load to my highest load at 3k(2.50) to 16.0d and the car run great actually stronger than before. and still giving me full DA. But now I have to smooth-out the timing at lower loads because the car feels weird when it goes from the stock timing bellow 1.0 load to the new timing(16d).
STLSTI is offline   Reply With Quote
Old 03-01-2007, 03:01 PM   #34
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
http://www.cobbforums.com/forums/sho...d=1#post440526
Here's a thread I started on Cobb forums. This guy 'Drifter' had some different opinions. He seemed to think that it wasn't pulling timing.
I'd really appreciate if you took the time to look at it. I'm can tell if Im more confused now or not lol. thanks.
Old 03-01-2007, 03:04 PM   #35
Enginerd
Fav Mod: Tuning
I have the day off so maybe Ill try this now. However I am skeptical because this occurs no matter what RPM/load site I punch the gas at...
Old 03-01-2007, 03:10 PM   #36
Car: Slow 05 STi
Fav Mod: Loping Idle
Ding, I'm a genius! Funny when some accidents turn into miracles.
Old 03-01-2007, 03:24 PM   #37
Car: 07 335
Fav Mod: NOISE
Thanks again for the help, and again, and again. Anyway I need to log more tomorow just to make sure.
Old 03-01-2007, 03:38 PM   #38
Enginerd
Fav Mod: Tuning
Im in the process of this right now(1-2.5 load timing change). Should I bias it more towards DA or PI. All in PI? All in DA? I figure since its such a low amount of timing I might be safe putting it all into PI and making the corresponding rpm/load sites in the DA tables '0'.
What do you think?
Old 03-01-2007, 03:51 PM   #39
Car: 07 335
Fav Mod: NOISE
I did all my changes to the PI but I don't think it really matters
Old 03-01-2007, 04:04 PM   #40
Enginerd
Fav Mod: Tuning
Im sitting here realizing my gas mileage may very well be going to ****!
Old 03-01-2007, 04:10 PM   #41
Car: 07 335
Fav Mod: NOISE
I hear you, it seems like every time I go out to do a log the car burns about a 1/4 of a tank.
Old 03-01-2007, 04:13 PM   #42
Enginerd
Fav Mod: Tuning
I was mainly talking about the timing Im changing in the lower loads. My logs show upwards of 25degrees there....now its only going to see 16..lol
Old 03-01-2007, 04:15 PM   #43
Enginerd
Fav Mod: Tuning
Well actually, Im going to try this first.
Old 03-01-2007, 04:48 PM   #44
Fav Mod: mo boostaz
Understood. Admittedly, I didn't take a lot of time to read the whole thread (due to family stuff going on). I just wanted to throw something in as a just in case.
t
Old 03-01-2007, 05:18 PM   #45
Enginerd
Fav Mod: Tuning
Here is what my weak timing curve is like at the moment. This is total timing
