Old 02-07-2007, 09:19 PM   #1
Car: 05 CGM FXT
Default I think this is what boost creep looks like logged
Code:
TPS     RPM     BST     WGDC    LOAD  TURBODYN   AFR
28	3296	-1.31	14.9	1.25	240.61	14.01
66	3331	6.38	30.59	2.06	282.91	14.41
66	3331	6.38	30.59	2.06	282.91	13.02
66	3331	6.38	30.59	2.06	282.91	12.19
100	3385	14.79	48.63	3.21	224.25	10.98
100	3385	14.79	48.63	3.21	224.25	10.26
100	3385	14.79	48.63	3.21	224.25	9.95
100	3449	20.02	40.78	3.57	-53.13	10.14
100	3449	20.02	40.78	3.57	-53.13	10.2
100	3449	20.02	40.78	3.57	-53.13	10.32
100	3523	19.14	34.51	3.33	-26.75	10.82
100	3523	19.14	34.51	3.33	-26.75	11.04
100	3523	19.14	34.51	3.33	-26.75	11.19
100	3570	17.69	45.88	3.21	70.48	11.3
100	3570	17.69	45.88	3.21	70.48	11.16
100	3570	17.69	45.88	3.21	70.48	11.17
100	3663	18.56	44.71	3.38	34.72	11.14
100	3663	18.56	44.71	3.38	34.72	10.98
100	3663	18.56	44.71	3.38	34.72	10.95
100	3715	19.14	43.53	3.41	-3.28	10.92
100	3715	19.14	43.53	3.41	-3.28	10.94
100	3779	19.44	42.75	3.39	-7.67	11.01
100	3779	19.44	42.75	3.39	-7.67	10.97
100	3856	19.44	41.96	3.38	-12.07	11.1
100	3909	19.44	41.18	3.36	-13.95	11.05
100	3909	19.44	41.18	3.36	-13.95	11.01
100	3909	19.44	41.18	3.36	-13.95	11.16
100	3957	19.58	40	3.33	-12.07	11.1
100	3957	19.58	40	3.33	-12.07	11.13
100	4030	19.58	38.82	3.34	-13.32	11.07
100	4030	19.58	38.82	3.34	-13.32	11.08
100	4099	19.44	38.04	3.35	-14.58	11.04
100	4099	19.44	38.04	3.35	-14.58	11.01
100	4099	19.44	38.04	3.35	-14.58	11.05
100	4154	19.58	35.69	3.34	-17.72	11.04
100	4154	19.58	35.69	3.34	-17.72	11.16
100	4241	19.73	30.2	3.38	-27.76	11.11
100	4241	19.73	30.2	3.38	-27.76	11.16
100	4241	19.73	30.2	3.38	-27.76	11.14
100	4284	19.87	22.35	3.42	-35.29	11.1
100	4284	19.87	22.35	3.42	-35.29	11.05
100	4284	19.87	22.35	3.42	-35.29	11.07
100	4350	20.31	15.29	3.44	-50.99	11.04
100	4388	20.74	5.1	3.46	-71.07	11.07
100	4388	20.74	5.1	3.46	-71.07	10.98
100	4458	21.03	0	3.49	-85.51	10.97
100	4458	21.03	0	3.49	-85.51	10.88
100	4458	21.03	0	3.49	-85.51	10.89
100	4509	21.03	0	3.52	-94.92	10.92
100	4509	21.03	0	3.52	-94.92	10.88
100	4509	21.03	0	3.52	-94.92	10.86
100	4543	21.03	0	3.48	-99.94	10.82
100	4543	21.03	0	3.48	-99.94	10.89
100	4543	21.03	0	3.48	-99.94	10.88
Intake air temp 21 degrees at sea level. Time to ditch the turbo and get something with a 8cm2 and properly ported.. =)
ZuMBLe is offline   Reply With Quote
Old 02-08-2007, 04:08 AM   #2
Car: 07 335
Fav Mod: NOISE
What turbo are you running?. What is you target boost?.Did you try lowering the WDC before 3500 rpm to try to avoid the spike to 20 psi.
STLSTI is offline   Reply With Quote
Old 02-08-2007, 04:13 AM   #3
Car: 05 CGM FXT
Target boost is 19 psi. The spike is actually pretty minor. The problem is towards the bottom of the log the wgdc is 0 and boost was still rising.
Old 02-08-2007, 04:52 AM   #4
Moderator & ECU Tech
Fav Mod: mo boostaz
What turbo and from whom?
t
Old 02-08-2007, 05:56 AM   #5
Car: 07 335
Fav Mod: NOISE
Wow that's crazy. I guess you are not running the stock VF39. Also I'm a noob but is the first time I see creep so high in the RPM band. I was under the impression that creep was only a problem during initial WOT. BTW did you try to changing the boost temp comp?
Old 02-08-2007, 06:21 AM   #6
Car: 05 CGM FXT
WGDC is at 0. I don't see how changing the boost comp would help. =P My boost temp comp is set at -14% below 33 degrees. So its been applied already.. hehe.
Old 02-08-2007, 06:22 AM   #7
Car: 05 CGM FXT
Its a deadbolt TD05H-16G so its kind of expected. Just a excuse to go with a 20g with a 8cm2. Interesting to see it logged. This is real boost creep I think. Nothing you can do with a tune will fix that. Haha..
t
Old 02-08-2007, 06:33 AM   #8
Car: Slow 05 STi
Fav Mod: Loping Idle
Thats creep ok, looks very similar to my last tune of Eddies car:
Old 02-08-2007, 07:05 AM   #9
Car: 05 CGM FXT
Well, hopefully people will now know to log before going around screaming saying they have boost creep. These two examples are real boost creep. If your logs look similar something mechanical needs to be done to fix it.
Old 02-10-2007, 03:31 PM   #10
Car: 05 OBP STi
Fav Mod: My Right Foot
Hehe. I was screaming boost creep before I logged. But, I had experience with creeps before on different cars, so it wasn't hard for me diagnose it. But yeah, +1 on the need for a mechanical fix. I ported wg before, but I'm too lazy to pull the turbo just to port the wg. I think I'm going down th meth route as Jeff has suggested. It would be nice to feel what chilled 22psi feels like.
Jeff, I'll get you more logs with the latest revised map soon. Been a little busy lately.
RdRacer301 is online now   Reply With Quote
