Old 02-06-2007, 09:13 AM   #1
Car: 06 Evo IX SE
Default Crystal or Wolf...Can I take a peek?
Hi guys,
I've been working on my first custom StreetTuner map for my car this past week, and would like to see how some of my modified values compare to the pros.
Do either/both of you have any of your own custom Stage 2 (stock intake, KN panel filter, Cobb catted TBE) maps you'd be willing to share with me? Please specifiy what fuel octane level the maps were made for. The map I'm working on is made for 95 octane since that's all I ever run. Keep in mind I have an 06 STI, so if you could convert your maps to be readable with my 06 STI StreetTuner software, that would be great.
Thanks in advance!
06stiman is offline   Reply With Quote
Old 02-06-2007, 09:40 AM   #2
Car: Slow 05 STi
Fav Mod: Loping Idle
Trader Rating: (12)
I wouldn't feel comfortable distributing my exact map, but would be willing to take a look at yours and give you some feedback.
Old 02-06-2007, 09:49 AM   #3
Moderator & ECU Tech
Fav Mod: mo boostaz
^ What he said. Mine has 22psi specified and is tailored to a GM BCS, FMIC, 70mm MAF, and 720cc injectors. It would be very dangerous in somebody else's hands.
t
Old 02-06-2007, 10:15 AM   #4
Car: 06 Evo IX SE
I appreciate your caution.
Since my site subscription is still being processed and I can't yet post attachments, can you both PM me your email addresses so I can send my map over.
Thanks!
Old 02-06-2007, 10:47 AM   #5
Car: 07 335
Fav Mod: NOISE
Hey 06stiman you can try Jorges map. its actually posted here so I think it Ok with him here's the thread As promised: An example of a catback stage 2 setup for a 2005 STI
Stage 2 with different timing AVCS setting and K&N intake
STLSTI is offline   Reply With Quote
Old 02-06-2007, 03:12 PM   #6
Car: 06 Evo IX SE
Thanks STLSTI, but it looks like Jorge's map was made with only a cat-back exhaust, not the full TBE setup. So I don't think it would be appropriate for my setup.
Old 02-06-2007, 05:13 PM   #7
Car: 07 335
Fav Mod: NOISE
Oh yea I know but with street tuner you can fix that.
Old 02-06-2007, 05:50 PM   #8
Car: Slow 05 STi
Trader Rating: (12)
Couple of quick notes to touch on (haven't gotten a chance to go through it all yet):
-For 95 oct. you should be able to run more timing, especially at lower rpm higher load points. That area needs a good amount of work and smoothing.
- Is there any reason why you are not using my rescaled map that I posted in the other thread? Your loads scales are way too low if your targeting 18.5 psi
-The golden rule (tuners style/pref) to a nice map is smoothness. That said, use that for ignition, da, boost, wgdc, avcs, and etc.
-Notice the fuel variences in the fuel map from load to load(high).
#1 you need to rescale you loads. Then work from there. For someone just getting into tuning, I suggest you play with the OTS rescaled map before you start fudging with smoothing, interpolating, avcs, and etc. Research turbo dynamics (make a world of difference and 'safety') and get you boost and wgdc dialed in. Next if you have a wideband get your fuel dialed in (pref rich at this point at least 10.8-10.9:1 nothing leaner for now) and playing with the intake calibrations along with the fuel targets to do so which will help you smooth out the map. When you get the in place move on to ignition. Look at the stock curve and see where there are 'bumps' in the road and where it is smooth. You will notice trends and in the mean time take a million thousand logs to see what you car likes and doesn't like in terms of timing. Your logs will teach your more than you think (more than any book or forum IMO). Thats it for now.
Old 02-06-2007, 06:06 PM   #9
Car: 07 335
Fav Mod: NOISE
^^^ Amen
