Old 02-05-2007, 03:34 PM   #16
Car: 07 335
Fav Mod: NOISE
IWSTI Addict since: Aug 2004
Originally Posted by crystal_Imprezav
DA A only map. This untested but I have been told it is a map that uses only DA A. Anyone who DL this please feel free to test it out and report back.
Link to Basemap DA A Only:
Click here for Wolf/CI Basemap DA A Only
Works just like a normal Stage 2 91 oct.
Thanks, Crystal
Marcos
STLSTI is offline   Reply With Quote
Old 02-05-2007, 05:02 PM   #17
Car: Slow 05 STi
Fav Mod: Loping Idle
IWSTI Addict since: Mar 2005
Trader Rating: (12)
Thanks, Crystal
Marcos
The question is, does it in fact only use the DA A table... To test out, set all the values on DA A the same say 8 or leave it at 10 and then change B to say either something lower or higher or 0 and do the same for C. Do some logs and see whether it is infact only using A or if it is interpolating with another table then report back. Thanks
Old 02-05-2007, 05:39 PM   #18
Car: 07 335
Fav Mod: NOISE
Well so far it seems to be following only DA A. I did use my own primary timing with different DA A values and every time had the same result the same number on the DA advance. I will try a different value in B and C to see what happens.
Marcos
Old 02-05-2007, 06:24 PM   #19
IWSTI Club Level 1
Car: The Spaze Mobile
Fav Mod: Tuning
IWSTI Addict since: Jan 2006
Honest question..:Why use the DA A only map when you can set A, B, and C to the same values?
Is it just for ease of use?
Old 02-05-2007, 06:41 PM   #20
IWSTI Club Level 1
Fav Mod: Tuning
What kind of logic did you use when you took out timing of the Primary ignition table? Just curious is all..
Old 02-05-2007, 07:21 PM   #21
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
IWSTI Addict since: Jul 2004
Some people have run into the map size limit when changing that much stuff. This was a fix to get around that a while back.
Old 02-05-2007, 08:10 PM   #22
Car: Slow 05 STi
Trader Rating: (12)
^^ Yup it saves a lot of basemap memory use to allow more basemap calibrations.
Old 02-05-2007, 08:11 PM   #23
Car: Slow 05 STi
Trader Rating: (12)
Excel
Old 02-05-2007, 08:57 PM   #24
IWSTI Club Level 1
Fav Mod: Tuning
My bad...
Old 02-06-2007, 07:17 AM   #25
Car: 07 335
Fav Mod: NOISE
Crystal it works like a champ. I have DA B and C set to zero and still get 5's on DA A.(DA A=5)
Old 02-06-2007, 08:21 AM   #26
Car: Slow 05 STi
Trader Rating: (12)
Excellent, good to know.
Old 02-06-2007, 08:06 PM   #27
IWSTI Club Level 1
Fav Mod: Tuning
My bad...
Well...I didnt know all you had to do was add the Primary ignition to the DA to get total ignition.
A couple of threads over on Nasioc confused me. Is it possible for the ECU to add timing OVER DA + P.I.?
Old 02-06-2007, 10:13 PM   #28
Car: Slow 05 STi
Trader Rating: (12)
Yes and no, I responded to your PM. Ill keep the thread updated when I figure out what he is talking about.
