Old 01-21-2007, 04:40 PM   #1
Car: 05 Aspen STi
Send a message via AIM to thekrazyasian
Default street tuner help
ok here i am after putting on my gruppe-s headers, helix dp and up, i have the ap and want to run the st but it isn't loading up saying that if can't find the ecu. what could i be doing wrong?? what can i do different? all help is appreciated.
-Ed
thekrazyasian is offline   Reply With Quote
Old 01-22-2007, 05:01 AM   #2
Car: 05 CGM FXT
Did you flash the street tuner base map yet? When you install street tuner on to the computer it asks for you to hook up your AP. It will then put the ST base map on to your AP. You need to flash that base map before you can connect to the car via ST.
-Ed
ZuMBLe is offline   Reply With Quote
Old 01-22-2007, 05:33 AM   #3
Car: 05 Aspen STi
yes i have the ST base map on teh car right now but when i try to connect it says that it is unable to connect i don't know what im doing wrong, is there some kind of different cable that i need?
Old 01-22-2007, 08:00 AM   #4
Car: 07 335
Fav Mod: NOISE
Make sure the ST program has the correct COM port selected.
STLSTI is offline   Reply With Quote
Old 01-22-2007, 05:01 PM   #5
Car: 05 Aspen STi
thanks i will try that tonight
