Old 01-19-2007, 11:00 AM   #1
Car: 06 Evo IX SE
IWSTI Addict since: Jan 2006
Default Suppose I want to tune my new 20G setup myself...
I currently own an 06 STI with Cobb AP and Cobb catted TBE. I intend to upgrade to the following setup soon:
1) 2.4" FP20G 8cm IWG turbo
2) Deatschwerks 740cc injectors
3) Walbro fuel pump
4) Perrin inlet tube
5) NGK 1-step colder plugs
6) Prodrive boost solenoid
Everything else on the car will remain stock.
I was considering purchasing Street Tuner and attempting to tune the new setup myself. Could someone list all of the Streetuner tables (in the order they should be modified) I would likely have to modify to get the above setup running smoothly? I'm currently thinking the following ordered list:
1) Fuel Injector Scale
2) Fuel Injector Latency
3) Boost Target (verify running rich first)
4) Wastegate Duty Cycles (High & Low)
5) Primary Fuel (WOT only)
6) Primary Ignition (WOT only)
7) Dynamic Ignition Advance
Can someone please comment on this?
06stiman is offline   Reply With Quote
Old 01-19-2007, 02:59 PM   #2
Car: Slow 05 STi
Fav Mod: Loping Idle
IWSTI Addict since: Mar 2005
Trader Rating: (12)
There is already a 20G Calibration provided by Cobb as a starting point for a 20G setup. The only thing that is different is the injector type which in turn would require you to calibrate you fuel injector scale/latency and also your intake calibration. Other than that, tuning would be just like any other tune. Modifications to the timing, fuel (maybe depending on the state of your intake calibration), and boost would be the only 'necessary' calibrations for the car to run right (all lowered). When the fine tuning begins, things like AVCS, FIBTE, and etc. can be tuned to your likings.
