Old 01-04-2007, 03:20 PM   #121
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
Wouldnt it suck if it came down to it that the issue really is just a loose ground wire. I have been picking my brain on this thread and have no other answer.
Old 01-04-2007, 04:12 PM   #122
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
I don't think it's that. Look at the chart. The uber rich situation occurs at the same time there is a bump in maf.
wait..... why is there a bump in the mafV right there?
Old 01-04-2007, 04:19 PM   #123
Car: 05 STi CGM
Fav Mod: JDM Foglights
Originally Posted by 04stiguy
Fourth gear.
Although its small, its interesting to note the small increase in MAF voltage at the exact point AFR goes rich. why would that be? Its also near wastegate opening, could this be from the restricter pill mod? I don't know, I'm just throwing some ideas out there... FWIW, it may be useful to run a higher resolution run concentrating on 3,400 to 4,000, there may be some useful data that is being missed. Just trying to keep the thoughts flowing...
SCOOBYTRAP is offline   Reply With Quote
Old 01-04-2007, 04:42 PM   #124
Car: '05 STi
Fav Mod: Cusco Zero 2R's
There is no restrictor pill mod on this car. Using a Tial 44mm EWG and Eboost2.
The MAF bump is also what I have been pondering for the last 18 hours. Possible compressor surge that is causing the MAF to blip voltage up for a sec.?
Also, Wolfplayer, I am wondering what kind of total timing values you have at the rich spot. Maybe a combo of:
>timing value too low
>accompanied by slightly rich condition set off by MAF "noise"
>which would lead to a light misfire and raw fuel in exhaust...
MAF bump could also be a function of the pipes/FMIC in the process pressurizing. When discharge tract stabilizes, so does MAF signal.
just thinking out loud..
04stiguy is offline   Reply With Quote
Old 01-04-2007, 05:45 PM   #125
The boost curve suddenly changes in that area too. 6-12psi takes about 400 rpm. 12-17 ish happens in 100 rpm. Maybe some sort of safety triggered of of a too aggressive boost curve. Just reaching here.
Old 01-05-2007, 02:31 AM   #126
Car: 05 STi CGM
...also how is the load calculated?
Old 01-05-2007, 05:22 AM   #127
Moderator & ECU Tech
Fav Mod: mo boostaz
First, definitely not a grounding issue. I have a grounding kit that redistributes the grounds to various parts of the motor/body (and, yes, the manifold grounding wires are UNDER the FMIC tabs).
t
Old 01-05-2007, 05:59 AM   #128
Fav Mod: mo boostaz
Here is a graph of the log I posted on page 3. I tried to use the same colors as the other graph posted above while graphing the same thing.
Old 01-05-2007, 06:07 AM   #129
Fav Mod: mo boostaz
Regarding the MAF V spike, it is possible that this could happen because of the richness. Think about it. The car is building boost and starting to pull. All of a sudden a crazy amount of fuel gets injected into the motor. It's rather obvious to me that the car will slow down, MAF V will drop, load will drop, etc.
t
Old 01-05-2007, 08:54 AM   #130
t
I see what you're saying. Rather than looking at it like an upward bump you are saying that it's just a sudden falloff because of power loosing richness. If the rich 'event' didn't happen the MAF would still have the same initial curve but it would be smoother after the peak.
Old 01-05-2007, 09:17 AM   #131
Fav Mod: mo boostaz
Absolutely. This is something that you can clearly feel. So, there is definitely a loss in power at that point. The MAF V going downward - or simply maintaining instead of continuing the upward trend - seems to bear this out as one would expect.
All I know is that if I could maintain 11:1 then this car would be an animal. I'm pulling 4.5 maf v on a 70mm MAF.
t
Old 01-05-2007, 09:23 AM   #132
Fav Mod: mo boostaz
I think 04stiguy's graph shows this more clearly than anything else. He has a turbo that once it begins spooling will spool very quickly and create a large change in MAF V and load over a very short period of time. Check out how his boost skyrockets between 3490 rpms and 3590 rpms. This will create a huge change in MAF V and a huge change in load. The graph clearly shows that. It also shows the AFR going crazy rich at that point.
Somebody gimme enrichment vs. delta MAF (or delta load)!!!!! If there is no delay parameters then this can be modified to help out a great deal!
t
Old 01-05-2007, 10:28 AM   #133
Car: '05 STi
t
Cobb sponsors this forum correct? Christian HELP! I really dont want to go to a blow through.....
Old 01-05-2007, 10:34 AM   #134
Fav Mod: mo boostaz
Christian is pretty darn busy right now. I've talked with him quite a few times about this issue and he said on bigger turbo setups he has always been able to get things to work by adjusting the FIBET. Have you adjusted your FIBET yet? If so, what is the current value you are using?
t
Old 01-05-2007, 10:46 AM   #135
Car: '05 STi
t
I agree to a point... It actually starts out as a positive spike, then goes into a mild dip after the rich spot. It is sensing reduced airflow caused by the rich condition, possibly a mild misfire. You can certainly feel it at times.
