Old 12-22-2006, 07:29 AM   #46
Originally Posted by crystal_Imprezav
I kept it to keep it more sleeper.
Sleeper? Black core = sleeper. Silver core = not sleeper.
Old 12-22-2006, 07:39 AM   #47
Car: Slow 05 STi
Fav Mod: Loping Idle
Ha yea, I know but I don't want to spray it and powder coating is too expensive. I am going for a look like this:
Old 12-22-2006, 07:42 AM   #48
That does look slick.
Old 12-22-2006, 10:14 AM   #49
Moderator & ECU Tech
Fav Mod: mo boostaz
Tim, you wanna email me your map so I can take a look at it. My suspicion is that you are running too rich of a afr, at lower rpm's which is causing an even richer spool with the FMIC being that the track is longer. Since you were running close to a 10.3:1 before, it really doesn't surprise me that your dipping into the 9's now.
Crystal,
It's DEFINITELY not that. Why? It does the same thing no matter WHERE I spool. It does it between WOT shifts too. The weird thing is that I can start a WOT pull from 2000rpms. At full spool ~3000rpms it will dip to 9.x AFRs. I hold it at WOT and it goes back to 10.8-11.0 AFRs - even at 5200rpms. Now, lets do this over but start WOT around 5000rpms. It will dip into the 9's @ 5200rpms (even though it was 10.8-11.0 in the previous WOT run). This, IMHO, has nothing to do with the AFR map. It's totally about something else ... either tip-in or a mechanical problem that only happens on spoolup. Grrrrr.
t
Old 12-22-2006, 11:45 AM   #50
Car: Slow 05 STi
Gotcha, I completely forgot about spooling up at higher rpms.
Old 12-23-2006, 07:00 AM   #51
Car: Sold 06 Aspen White/
Fav Mod: Meticulous Maintenance
Keep up the investigating Wolf. Watch it turn out to be something simple. That would be a blessing!
dareseven is offline   Reply With Quote
Old 12-24-2006, 01:54 PM   #52
Car: Slow 05 STi
Ok so I finally got everything done and good to go minus the meth (couldn't get my old nozzle out so I need a new one). Loaded up the pump map for 19psi and 11.1:1 AFR all the way through and went for a spin (no logs, too tired). Intial thoughts were that it is noticeably laggier at part throttle. The feeling felt most like when you have too much AVCS dialed in, if any of you know what that feels like. I then went WOT (from 2000rpm, 4th gear) and peak boost hit at around a little over 3200 rpm. Thats about a 200-400 rpm difference from the stock TMIC. Now up top it felt great, much more peppy than with the TMIC.
Now for the fun part, the AFR's. With the TMIC and this tune I would consistently pull a 10.9-11.1:1 afr with this exact tune. In every gear up to third, it was point on, the richest it ever got was 10.9:1 at peak boost and then right back to 11.1:1 through redline. Now in 4th gear, I did a hard load from 2000 rpms and the AFR dipped down to 10.4~10.5:1 right at peak boost and straight back to 11.1:1 there after. This seemed odd to me since it went from a mid 12:1 spool to 10.x immediately and then right back to where it should be. It does make a noticeable difference since the peak torque that you are used to feeling, is significantly decreased with the dip. Ill play around with some basemap parameters tomorrow and get some logs and report back. One thing that has not been mentioned that I am going to try is playing with MAF. Since peak boost hits at a specific MAF voltage range, I think that by lowering that part of the calibration, I will be able to get the spike to disappear with no ill effects. It may effect the spool up afr a bit but I wont mind that since with a leaner mix, it will yield faster spool.
Overall I am not too disappointed with it all. I think that I can get the spike to disappear and I can most certainly work on the spool up time. However I will not spend much time tuning the pump map since as soon as my new nozzle arrives I am going to dial my meth tune in with a lot of boost and some fine tuning up top to take advantage of the cooler charge.
Old 12-24-2006, 05:08 PM   #53
Fav Mod: mo boostaz
Be careful doing the MAF voltages. It'll definitely be a fudge and if you hit that at any point OTHER than the spoolup then you will be lean
t
Old 12-25-2006, 02:12 AM   #54
Car: 2006 Kawasaki Ninja
Fav Mod: Power Sliding doors on my Minivan beotch
Sorry to see the problems your having here wolf. hope you can get it figured out soon.
evodon84 is offline   Reply With Quote
Old 12-25-2006, 05:03 AM   #55
Fav Mod: mo boostaz
Now in 4th gear, I did a hard load from 2000 rpms and the AFR dipped down to 10.4~10.5:1 right at peak boost and straight back to 11.1:1 there after. It does make a noticeable difference since the peak torque that you are used to feeling, is significantly decreased with the dip.
VERY similar to what I am seeing. Only difference is that mine dips a little lower. This might be due to the fact that the DR525 has more volume than the EBay FMIC.
t
Old 12-25-2006, 05:19 AM   #56
Car: Slow 05 STi
No leaks here either. I used hairspray to coat the inside of the couplers before I tightened down the clamps. I tightened them down so much that I snapped one of the t-bolt clamps
Old 12-25-2006, 05:23 AM   #57
Fav Mod: Starving my STI
Hi... which reverse scoop are you using. It looks nice. I was thinking of going CF hood or something to replace that awful STI hoodscoop when going FMIC.
Old 12-25-2006, 05:25 AM   #58
Car: Slow 05 STi
t
Right, but I will have meth as a safety measure, however looking at a bunch of logs, with my intake calibration whenever I hit full boost from spool it always hits at 4.3v. If you take a look at the AVCS logs I sent you awhile back you will see this. By lowering the volts right before full boost and at that 4.1~4.3 mark I should be able to lean out the mix and it should accurately reflect the amount of air going into the motor being that the pressure drop and delayed air volume will combine to produce less manifold air/pressure than with the TMIC, or at least I hope since nothing else seems to be working effectively.
Old 12-25-2006, 05:30 AM   #59
Car: Slow 05 STi
That is a Seibon reverse scoop (http://www.gruppe-s.com/Subaru/subext.htm) I believe. That is not my car, I am using a regular wrx scoop and plan on getting a RS hood or just leaving the wrx scoop. Here are some finished pics:
Old 12-25-2006, 12:31 PM   #60
Fav Mod: mo boostaz
I'm just glad that I am not the only one seeing this. How the heck can we go through 3 complete model years ... AND start a 4th model year and nobody has reported this? So far, I have seen it - you have seen it - and daemon has seen it. Oddly enough, it's the 3 people in this StreetTUNER forum who actually tune their own cars. rofl.
Merry Christmas. It's just too bad that we can't present a nice solution to this issue - all wrapped up with a bow on top, hehe. Santa? Santa?! SANTA!?!?
t
