Old 01-16-2007, 02:55 PM   #196
Car: 08 Z06 Corvette
Fav Mod: Jack Jack
IWSTI Addict since: Oct 2005
A capacitor or resistor (or any steady state electronics) cannot create a "delay". They can only filter faster or slower transients.
I would not consider such a mod worthwile. The necessary delay will be relative to how fast the air is moving and where on spool-up it is. No simple electronics can do that for you. A microcontroller like a 68HC11 might offer what you want... but probably isnt worth the trouble.
Chris
Originally Posted by daemon
I've thought about it. In the absolute simplest form, a resistor and a capacitor could be used to "smooth" out voltage transitions. However, I believe you'd actually only want to smooth out an increase in voltage and not a decrease (since when the throttle slams shut, it slams shut). For that, possibly add a diode to allow the voltage to bypass the resistor when discharging.
However, I'm not an electrical engineer either and there are a decent number of unknowns for me. I tried running a few numbers to see just how big a resistor and capacitor would need to be to get a ~100ms delay (a basic starting point), and the values seemed a bit higher than I would like. To use a small resistor so as to not effect the amount of current in the circuit would force us to use a pretty darn big capacitor. To get the capacitor to a reasonable size would require a large resistor (not physically large, but large enough in value to possibly hose the current levels). Of course, I could have gotten the numbers all wrong.
Either way, the circuit is a simple one, so it might be "fun" to just throw on some components and hope I don't fry anything important. Actually, frying wouldn't be likely IMHO, for whatever that is worth.
And, fwiw, a capacitor's charge time is not a linear slope. The proper solution might be a microcontroller with an onboard ADC/DAC and then just write a mini-program to translate and delay as needed.
RainMaker is offline   Reply With Quote
Old 01-16-2007, 03:05 PM   #197
Car: 2004 STi
IWSTI Addict since: Feb 2004
Notice I used the word "smooth".
Old 01-25-2007, 06:48 AM   #198
Car: 03 mbp gga
Fav Mod: 12.9 / 105+
IWSTI Addict since: Dec 2005
Send a message via AIM to ride5000
not necessarily true.
all reactive circuits create some amount of phase shift.
depending on the input this may or may not result in a signal "delay."
ride5000 is offline   Reply With Quote
Old 01-25-2007, 04:29 PM   #199
Fav Mod: Jack Jack
Awwwww... that was not fair. True, but a phase shift means a fraction of a wavelength in time... not enough to spool a turbo
Old 01-26-2007, 06:22 AM   #200
Car: 03 mbp gga
i do agree that trying to achieve what is proposed is impossible with LRC circuits.
i'm starting to think that there may be a "delay" register buried somewhere in the ecu code that is based on intake tract volume between the mafs and the combustion chambers.
ken
Old 01-26-2007, 07:23 AM   #201
IWSTI Addict since: Apr 2004
ken
My thoughs exactly.
I have tuned a blowthrough and have read about other people with a blowthrough. The rich dip is not there when using the blowthrough setup. IMO it is a delay between when the MAF reads the airflow and when the airflow reaches the motor.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-31-2007, 04:57 PM   #202
Car: Slow 05 STi
Fav Mod: Loping Idle
IWSTI Addict since: Mar 2005
Trader Rating: (12)
Hmm interesting find...
http://www.maftpro.com/tproinfo.shtml
Old 01-31-2007, 05:11 PM   #203
Car: 2004 STi
Originally Posted by crystal_Imprezav
Post #101.
Old 02-01-2007, 03:37 AM   #204
And for the price you would be better off with a used Utec.
$399 for the control box
$12 for the IAT
$69 fot the 3bar MAP
$22 for the IAT harness
$24 for the universal harness
Comes to ~$530 + shipping.
TMS
Old 02-09-2007, 04:16 PM   #205
Car: '05 STi
Fav Mod: Cusco Zero 2R's
IWSTI Addict since: Jun 2004
Interesting AFR plot on post #1, third chart down. Also read post #50.
http://forums.nasioc.com/forums/show....php?t=1195987
04stiguy is offline   Reply With Quote
Old 02-09-2007, 11:02 PM   #206
Car: Slow 05 STi
Trader Rating: (12)
Shocker, I am working on a solution, turning my trades to reverse engineering...
Old 02-10-2007, 11:12 AM   #207
Super Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
Reverse engineering FTMFW!!! I hope you are successful!
Old 03-19-2007, 11:55 PM   #208
Car: '05 STi
Minor update. Switched to a blow-thru tonight. Intial drive shows promise. Very smooth. No change in tune intially, and it drives great. I will log stuff in the next few days.
Old 03-20-2007, 08:00 AM   #209
Car: Slow 05 STi
Trader Rating: (12)
^ Going the same route.
Old 03-20-2007, 08:14 AM   #210
Super Moderator
Fav Mod: Majin
What happened to the reverse engineering???
