| | #181 |
| Spec C Club Car: Slow 05 STi Fav Mod: Loping Idle Location: Chewy's Garage Posts: 1,877
IWSTI Addict since: Mar 2005 Trader Rating: (12) | Haha you can say that again. I am messing around with an FXT with a VF39, 04STi ecu, and WRB FMIC, and he is displaying the same thing. He has perrin 816cc injectors and is hitting a daggering 10.2:1 afr from 3000-3300rpms. Its not just us! And he also has -80% FIBTE so that def. does not just apply to our cars. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #182 | |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,759
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
I hit 9.8:1 on spoolup most of the time. Yes, it suxorz. Yes, I have lost torque on spoolup. Yes, I don't like this. .... ... .. . Yes, I am a glutton for punishment and am keeping my FMIC. I want Speed Density. Screw the MAF in setups like this. t | |
| | #183 | |
| The Next Petter Solberg Car: 08 Z06 Corvette Fav Mod: Jack Jack Location: Portland, OR Posts: 882
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Quote:
Then again, I was yelling and making noise form the rooftops about tip-in inconsistencies with a Front mount or a blow-through for a long time and I got alot of brush-offs from the tuning pros and their software designers. The TMIC was in some ways a great excuse to go back to a nice smooth throttle response. | |
| | #184 | |
Somebody needs to uncover some more tables or else there really isn't a choice. I'm willing to experiment and change stuff. But, I have changed everything possible (I think) at this point. So, there is nothing left for me to try - except to convert to blow-through ... and, honestly, after seeing your issues with blow-through and hearing about how a lot of tuners are now shying AWAY from blow-through and converting back to pull-through, I am really hesitant about moving in that direction until more tables are opened up.t | |
| | #185 | |
| Silver Member Car: '08 WRB SG Model D Fav Mod: All of them... Location: The Wild Serengeti Suburb Posts: 493
IWSTI Addict since: Dec 2006 Trader Rating: (4) | Quote:
| | #186 | |
IWSTI Addict since: Mar 2005 Trader Rating: (12) | Quote:
| | #187 | |
| | #188 |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | I think everyone will be really surprised how well SD works in situations like this. I've tuned SD setups for a long time. I actually really like them (once tuned). IMHO, SD setups are more for tuners who like futzing with stuff and MAF setups are more for people who like the ECU to have more control. t |
| | #189 | |
t | |
| | #190 |
| Spec C Club
Car: 07 STI LTD/08 STI Fav Mod: APS/Crawford/Cosworth/Aquamist Location: E-town, AB Posts: 2,413
IWSTI Addict since: Apr 2005 Trader Rating: (5) | I just can't see myself installing my FMIC now. 1) Lack of throttle response; 2) Lost low end torque and; 3) Rich spikes between shifts. Nice. WP, if you had all this experience with tuning your FMIC before installing it, would you still have put it on? Do the benefits of the FMIC (after getting going) outweigh the negatives? |
| | #191 | |
With the pump gas VF39, I would not install a FMIC again. I would install a larger TMIC. With a big turbo, I would keep this FMIC because the safety benefit outweighs the negative things previously mentioned. At this moment, the negative aspects outweigh the gain in safety with this little VF39. The nice thing about the VF39 is the torque onset. It hits nice and good at a low rpm when tuned that way. When adding a FMIC, the rich spike gets rid of some of this. The gain in the topend doesn't make up for this (IMHO). Now, with a bigger turbo, all of that goes out the window. The gains and safety will outweigh the slight loss in torque due to rich spiking and mid-rpm lag. t | |
| | #192 | |
| Super Moderator | Quote:
| | #193 | |
Being willing to try something not many others have... FTW! | |
| | #194 | |
| | #195 | |
| The Next Petter Solberg | Quote:
However, I'm not an electrical engineer either and there are a decent number of unknowns for me. I tried running a few numbers to see just how big a resistor and capacitor would need to be to get a ~100ms delay (a basic starting point), and the values seemed a bit higher than I would like. To use a small resistor so as to not effect the amount of current in the circuit would force us to use a pretty darn big capacitor. To get the capacitor to a reasonable size would require a large resistor (not physically large, but large enough in value to possibly hose the current levels). Of course, I could have gotten the numbers all wrong. ![]() Either way, the circuit is a simple one, so it might be "fun" to just throw on some components and hope I don't fry anything important. Actually, frying wouldn't be likely IMHO, for whatever that is worth. And, fwiw, a capacitor's charge time is not a linear slope. The proper solution might be a microcontroller with an onboard ADC/DAC and then just write a mini-program to translate and delay as needed. This ad is not endorsed by this member. Please register or login to hide this ad. | |
