| | #166 | |
| Spec C Club Car: Slow 05 STi Fav Mod: Loping Idle Location: Chewy's Garage Posts: 1,877
IWSTI Addict since: Mar 2005 Trader Rating: (12) | Quote:
(4.7v) at less boost than my TMIC tune (for right now) and a stock diameter/stock typhoon (no ru2800 filter)! I did advance my AVCS about 2* more from what you previously saw of mine though.Check this bad boy out: This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by crystal_Imprezav; 01-09-2007 at 05:34 PM. | |
| | #168 |
IWSTI Addict since: Mar 2005 Trader Rating: (12) | Nope, thats really the only way you can tune meth/alky injection. That is unless you want to fudge severely with the intake calibration which will throw of loads and etc. For testing purposes i actually tested out a very similar fuel table with 14.7 up to 3600rpms and still no deal on getting the FMIC to lean out at all at that load/rpm site |
| | #169 | |
| Senior STI Driver | Quote:
I am still going to try out a blow through just for my own education after the draw thru is dialed. | |
| | #170 | |
| | #171 | |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,759
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
I lowered the area before 4v slightly. If I lower it any more then it won't make sense. Furthermore, I did some tests at part throttle so that I can keep the car in the 3-4v region. The AFR is on. IMHO, that is the key. Do some part throttle constant throttle logs of the 3-4v region (with no spoolup enrichment). THAT will tell you if that region is nuts on or not. You can't judge the MAF curve during spoolup because the lag can affect it. You have to judge it during constant throttle such that the motor can reach a steady state. t | |
| | #172 | |
| The Next Petter Solberg Car: 08 Z06 Corvette Fav Mod: Jack Jack Location: Portland, OR Posts: 882
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Quote:
. The box prior to the MAF is a box of aluminum honeycomb for laminar flow conditioning. Last edited by RainMaker; 01-10-2007 at 09:12 AM. | |
| | #173 |
IWSTI Addict since: Mar 2005 Trader Rating: (12) | ^^ I knew you would end up messing with that curve Looks similar to the one I emailed you a few weeks back, lol where you said you wouldn't want to mess with it. So part throttle you said looks on point but what about WOT? |
| | #174 | |
Just my $.02. Seems to be helping my setup quite a bit. | |
| | #175 | |
The curve is just on-point. I am testing steady state MAF V and comparing the fuel curve to the wideband. t | |
| | #176 | |
Don't get me wrong. I am sure that I could decrease that specific voltage area and get rid of a bunch of the dip. However, the intake calibration is not at fault. If anything, it is slightly too LOW in that area due to me fudging it a TINY bit (like 2%). Be careful about pulling that area down too low. You run the risk of part throttle lean fueling. You can run 3.7v at part throttle fairly easily in partial boost acclerating briskly. t | |
| | #177 |
| The Next Petter Solberg | I also double checked my intake calibration re: MAF voltage vs. AFR delta. The MAF areas where I logged a spike (~10+% delta) also tended to average less than a ~2% delta on a much more consistent basis. That is, the spike area of the intake calibration was more likely to produce the desired AFR then not (by a huge margin). Therefore, fudging the intake calibration would actually hurt me. |
| | #178 | |
Did the honeycomb help with the tip-in issues? | |
| | #179 | |
The honeycomb fixed turbulence at the MAF sensor, and didnt have any effect on tip-in once tuned. | |
| | #180 |
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Oh... on a final note... I successfully undid what Wolfplayer has done ![]() Operation Remove Front Mount and Blowthrough has been a success. I can stand on a boat and present Mission Accomplished because I *think* it went well, though Im not finished tuning yet. These pull-throughs with TMICs sure are easier to tune This ad is not endorsed by this member. Please register or login to hide this ad. |
