Old 12-05-2006, 09:52 AM   #1
Car: 05 CGM STi
Fav Mod: Seat Time
IWSTI Addict since: Jun 2005
Default Questioning engine load
I know this is designated as a subforum for the Cobb ST, but I think the ecu gurus in here may be able to explain this for me.
I have an 05 STI, currently running a STG2 OTS cobb ap map. Recently purchased a tactrix cable and have been educating myself and reading anything I can get my hands on. After pulling some 4th WOT logs, engine load was peaking around 3.2 ish around 3K RPMS, and holding above 3 until it tapers around 6K RPMS.
From looking at the stock ECU image tables , and others, it appears the fuel and timing tables only have parameters up until 2.75 load (g/rev). My question is what does the ecu look to running WOT with loads greater than 2.75 to provide fuel/timing? Or does the 2.75 load column just go to infinity?
I attached a log for reference.
File Type: zip ecuExplorer [AJ930-8791] 04-12-2006 20h35m00s.zip (1.9 KB, 3 views)
AmeenR is offline   Reply With Quote
Old 12-05-2006, 10:00 AM   #2
Car: 07 335
Fav Mod: NOISE
IWSTI Addict since: Aug 2004
Street Tuner n00b Tuning Primer
Look under engine load.
STLSTI is offline   Reply With Quote
Old 12-06-2006, 06:50 AM   #3
Car: 05 CGM STi
Fav Mod: Seat Time
AH HA! Thanks for the link. That's exactly what i was looking for!
