| Spec C Club
Car: Blue 05 STI Fav Mod: 4th gear wheelspin Location: Upstate NY Posts: 2,095
IWSTI Addict since: Nov 2004 Trader Rating: (0) | I've been running on basically the same tune for months now and finally started tweaking it again. Just looking for some pointers/tips for things that I could change. I am trying to get the car ready for the dragstrip this weekend. As it is, I need to rescale my maps again for the higher engine load. My maps max out at 4.0 load and I've seen 3.9x in datalogs. I still get a rich spike during boost onset. I understand that this is controlled by the Fuel Injector Boost Trim Error map (FIBTE), but I can't see that map with StreetTuner or Engenuity, even when using the latest ecu definition maps. How are people changing this? Anyways, on to the datalogs. How do my timing values look? I've been slowly adding timing around 5k with great results. 2nd gear spins all 4 now usually. Max boost here is around 24psi.. my avc-r targets 1.70. I plan on slowly bringing boost up to 26ish. For fuel I have 3 gallons of 110 to a full tank of 93, and I am spraying a 50/50 meth/water mix through an M15 nozzle with my SMC kit. It starts spraying around 12psi and maxes out at 26+ (I turned the max spray psi knob up all the way). My long term knock learning map is all 0's. Oh and check out the uber spoolup in the first log... full boost around 4400! and I am still on the cobb stg2 AVCS map.Code: Time IAT MAF Boost ThrottleMPH Load IDC RPM Dyn.Adv Timing AFR 37:45.8 70 1.64 -10.44 9 43 0.2 4.53 3033 0 35.5 0 37:46.1 70 2.64 -0.15 90 43 0.93 12.58 2949 2.5 39 12.76 37:46.5 70 2.78 1.02 100 42 1.26 15.12 3082 4.5 33.5 15.52 37:46.8 70 2.92 2.18 100 42 1.37 16.18 3160 5 31 14.92 37:47.2 70 2.96 3.34 100 42 1.48 16.74 3270 5 29 14.51 37:47.5 70 3.1 4.64 100 43 1.58 17.79 3336 5 27 14.11 37:47.8 70 3.16 5.95 100 45 1.71 20.28 3521 5 24.5 13.42 37:48.2 70 3.34 7.69 100 47 1.93 24.18 3656 5 20.5 12.95 37:48.5 70 3.54 10.15 100 47 2.18 28.44 3809 5 17.5 12.36 37:48.9 70 3.74 13.49 100 50 2.53 34.32 3924 5 15 12.08 37:49.2 72 4.08 18.71 100 52 3.21 48.17 4260 5 14.5 11.73 37:49.5 72 4.22 22.48 100 55 3.65 53 4436 5 14.5 11.13 37:49.9 72 4.3 22.48 100 55 3.6 56.16 4786 5 16.5 11.91 37:50.2 73 4.38 22.48 100 60 3.57 57.67 5006 5 17 11.82 37:50.6 73 4.42 22.48 100 65 3.53 61.27 5319 5 18 11.64 37:50.9 73 4.48 22.48 100 65 3.58 63 5469 5 18 11.5 37:51.2 75 4.52 22.48 100 70 3.52 64.43 5808 5 19 11.33 37:51.6 75 4.52 22.48 100 75 3.4 66.04 5953 5 19.5 11.57 37:51.9 75 4.54 22.48 100 80 3.28 66.63 6247 5 21.5 11.47 37:52.3 75 4.56 22.48 100 80 3.21 69.87 6550 5 23 11.23 37:52.6 75 4.56 22.48 100 85 3.1 68.66 6705 5 24 11.39 Code: Time IAT MAF Boost ThrottleMPH Load IDC RPM Dyn.Adv Timing AFR 37:00.2 79 3.14 1.74 100 16 1.36 20.12 4101 5.5 35 11.97 37:00.5 79 3.64 5.08 100 18 1.84 33.43 4897 5 28 11.76 37:00.8 79 4.34 13.49 100 21 2.79 60.57 5915 5 20 10.79 37:01.2 79 4.38 11.02 30 21 3.24 6.01 7042 5 29 10.86 37:01.5 81 1.98 -9.57 10 27 0.59 5.17 6055 0 24 19.54 37:01.9 81 1.96 -10.3 10 27 0.51 4.64 5440 0 24 15.33 37:02.2 82 3.5 5.37 100 32 1.77 29.28 4427 5 26.5 13.72 37:02.5 86 4.1 12.33 100 35 2.52 48.24 5139 5 21 11.08 37:02.9 88 4.58 22.48 100 38 3.63 74.31 6006 5 18.5 11.04 37:03.2 88 4.62 22.48 100 38 3.33 70.77 6770 5 23.5 11.73 37:03.6 90 2.56 1.89 15 42 1.56 6.17 7227 2.5 24.5 11.89 37:03.9 91 3.76 6.09 98 49 1.05 32.52 6627 0 41 19.02 37:04.3 93 4.36 17.84 100 54 3.15 63.81 5539 5 19 10.54 37:04.6 95 4.5 21.76 100 54 3.26 66.61 6122 5 20 11.13 37:04.9 95 4.54 22.48 100 58 3.23 67.39 6447 5 23 11.36 37:05.3 95 4.56 22.48 100 62 3.11 68.56 6838 5 24.5 11.45 37:05.6 95 3.86 -3.77 11 68 0.72 6.08 7126 0 24 11.52 37:06.0 95 3.78 5.37 100 68 1.2 33.81 6604 0 39 17.04 37:06.3 95 4.38 17.69 100 72 3.1 63.16 5586 5 19 10.44 37:06.6 97 4.36 20.6 100 75 3.29 63.66 5630 5 19 10.67 37:07.0 97 4.36 20.6 100 75 3.29 63.66 5630 5 19 11.32 37:07.3 97 4.48 22.34 100 77 3.25 65.73 6162 5 20.5 11.32 37:07.7 95 4.52 22.48 100 81 3.2 66.74 6385 5 22 11.27 37:08.0 93 4.54 22.48 100 85 3.15 68.48 6551 5 23.5 11.25 37:08.3 93 4.56 22.48 100 85 3.09 69.88 6824 5 24.5 11.38 Code: Time IAT MAF Boost ThrottleMPH Load IDC RPM Dyn.Adv Timing AFR 39:21.5 117 3.28 0.87 100 22 1.28 23.57 4803 2 38 13.32 39:21.8 115 3.48 2.9 100 22 1.58 29.98 5019 3.5 33 11.58 39:22.2 113 4.2 10.59 100 24 2.44 53.55 5977 5 21.5 10.5 39:22.5 111 4.68 22.48 100 24 3.27 6.12 7176 5 24.5 10.75 39:22.8 109 2.2 -9.57 10 27 0.7 4.68 5483 0 24 24.17 39:23.2 108 3.76 7.69 100 32 2.08 37.77 4918 5 24.5 13.88 39:23.5 108 4.44 18.13 100 37 3.22 64.73 5517 5 19 11.02 39:23.9 108 4.58 22.48 100 37 3.4 68.93 6462 5 22.5 11.48 39:24.2 108 4.6 22.48 100 41 3.12 72.85 7114 5 25 11.86 39:24.5 106 3.3 -8.99 10 47 0.55 4.89 5734 0 24 0 39:24.9 106 3.86 8.41 100 52 2.07 40.52 5134 5 25 13.82 39:25.2 106 4.44 20.16 100 52 3.36 67.86 5680 5 19 10.48 39:25.6 106 4.48 22.19 100 56 3.28 66.23 6087 5 20.5 11.32 39:25.9 104 4.52 22.48 100 60 3.2 66.96 6539 5 23.5 11.73 39:26.2 104 4.56 22.48 100 64 3.04 70.68 7049 5 25 11.6 This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,759
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Jay, I'll look at the logs when I get a chance. However, regarding the FIBTE map ... One option is to just e-mail Christian from Cobb and see if he'll change the value for you in your StreetTUNER map. Another option is to wait for Cobb's more advanced ST ... but, there is no idea how long of a wait that would be. Another option is that I thought I remembered some guy on enginuity requesting that map and the dude responsible for the definitions posting a test definition for him to test. I'm pretty sure it was in the definition discussion forum and it said FIBTE in the title (IIRC). If that doesn't help, then you could probably contact the same dude who created that test definition and see if maybe he will create one for you? I don't know. But, it might be worth a try. t |
| | #3 | |
| The Next Petter Solberg Car: 08 Z06 Corvette Fav Mod: Jack Jack Location: Portland, OR Posts: 882
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Quote:
| | #5 | |
| Junior STI Driver | Quote:
| | #6 | |
| Spec C Club
IWSTI Addict since: Nov 2004 Trader Rating: (0) | Quote:
I am really wondering how much timing is too much... I am limiting myself to 25 degrees up top but it seems to want more down low. | |
| | #7 |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Jay, That is correct! The table IS suppose to show up as all zeroes You're good to go. Mine currently shows "-29.xx" in every cell because I am subtracting 30%. So, no worries, it is suppose to show 0's on a stock image.t |
| | #8 |
| Spec C Club
IWSTI Addict since: Nov 2004 Trader Rating: (0) | Nice! I'll give this a try tonight. Now comment on my datalogs please |
| | #9 | |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
![]() Honestly, after reading that you were running 93 + 110 + meth/water injection, I really don't have the experience to comment on those logs. I think they look nice. But, honestly, that doesn't mean anything ![]() I like your use of flat dynamic advance. I like the high load values. I like the IDCs, Boost looks neato maxed out in the logs, 4.56 MAF volts on a ??? in maf? I assume 3"+ and that is moving some air. I can't really comment on overall timing and AFR due to 93 + 110 + meth/water injection. t | |
| | #10 |
| Spec C Club
IWSTI Addict since: Nov 2004 Trader Rating: (0) | It's a Perrin BigMAF... I am still using the 4" inlet hose and BigMAF that came with the Perrin GT35R kit. From what I have read, the MAF maxes out around 530whp on a dynapak... so I am happy with my numbers so far. I am going to push timing up a max of 1 degree at 4-5k rpms at high load and leave it at that. I still have the other issue that I posted about earlier, with hitting the dbw throttle cut between shifts. I changed the dbw table to give 100% at 7500 and 25% at 8000, with the rev limit at 7000/6900, and still hit it on fast shifts. I'm just driving around that problem for now, but it's going to hurt me at the track. |
| | #11 | |
| Grassroots STI Racer Car: 05 Subaru WRX STi Fav Mod: Cobb StreetTUNER Location: Elk Grove, CA USA Posts: 590
IWSTI Addict since: Jul 2004 Trader Rating: (0) | Quote:
I'm tired of waiting for ST ADV. I just emailed Christian to see about getting a tweaked basemap. The reason I'm posting is because christian's tuning worksheet v1.13 shows the stock FIBTE tables as full of 128 not 0. Which is it? Are they both the same just displayed different? PS my tactrix cable is on the way. | |
| | #12 | |
t | |
| | #13 |
| The Next Petter Solberg | For those non-computer geeks, 128 is the middle binary value of an 8 bit number (or byte). That is, the MSB (most significant bit) is one and all other bits are zero. For a signed byte, the MSB is the sign bit. So numbers 0 to 127 are as you'd expect. 128 is actually negative zero. 129 becomes -1, 130 becomes -2, etc. Therefore I assume Cobb is displaying the signed byte as an unsigned byte. Same string of binary numbers, just a different way of displaying the information. This ad is not endorsed by this member. Please register or login to hide this ad. |
