Old 10-10-2006, 05:39 AM   #1
Moderator & ECU Tech
Fav Mod: mo boostaz
Default Pretty sure I need a BOV
Yup. I think I might be going 'retro' and becoming a newb
I've been tuning to 20psi on spoolup because there is some testing I want to do. Anyhow, in 4th gear starting out at 2000rpms and going WOT, when she hits 3000rpms I have 20psi on tap with about 50% WGDC (EBCS). Then, almost immediately, pfshhht shht shht .... I lose about 1.5psi, AFRs go lean (recirculation), Turbo Dynamics shoot up, WGDC shoots up to compensate.
My first thought was that I had my turbo dynamics too high in the negative portion. Nope. That is definitely not it.
Egad. The last thing I wanted to do was to buy a new blowoff valve. However, I am toying with the idea of picking up another stock valve and doing the crush mod. Anyone done the crush mod yet?
t
Old 10-10-2006, 05:50 AM   #2
Fav Mod: when it's not blown up
I crushed mine. It worked, but I had some surge issues so I replaced it with a Forge BPV. I get the same surge issues with the Forge and I've come to the conclusion that maybe I am just trying to move too much air. Planning on switching to a Tial bov soon.
I used a c-clamp to crush mine. It crushes really easily so go slow.
Old 10-10-2006, 06:14 AM   #3
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (24)
Call up ImportImage...got mine for $144 shipped for the Forge Recirc BPV...thats 100% recirc.....def worth it!!!
Old 10-10-2006, 06:44 AM   #4
Car: 06 STi WRB
how bout the APS 50/50??? any good?
Tbagger is offline   Reply With Quote
Old 10-10-2006, 08:47 AM   #5
Fav Mod: mo boostaz
If I had the money I would just buy that and install it. But, I don't. So - I'm probably going to do a little bit of crushing on the stocker.
t
Old 10-12-2006, 05:34 AM   #6
Fav Mod: mo boostaz
I am beginning to think that it had nothing to do with the BOV. I crushed the stock bov last night (1/8")...
http://www.bescaredracing.com/sti/in...h/DSC06935.JPG
Full pics at ...
http://www.bescaredracing.com/sti/in...v/stock/crush/
I used a MityVac during this process. My stock bov (yes, I know it is a diverter valve but I like typing bov - lol) would start opening at 19in (verified with the MityVac). I crushed it 1/16" and finally to a full 1/8". Now it opens at 20in vacuum.
The problem was still there.
I decided to test the only thing left: Compressor Surge (cavitation). I delayed spoolup by 200rpms and now everything is fine.
One side benefit to doing this crush mod that was unexpected is that the car is just smoother on throttle tip in. It's hard to explain, but I definitely feel it.
t
Old 10-17-2006, 09:45 AM   #7
Well, if your crushed modded one fails then consider getting a JDM STi (Ver. 7) bypass valve. No tuning needed and it'll hold up to 25psi with no problems.
I just got one through an importer, but I haven't installed it yet. It was cheap, and is a direct bolt on!
nxwrxfx is offline   Reply With Quote
Old 10-17-2006, 10:56 AM   #8
Fav Mod: mo boostaz
Where did you get it and how much was it?
t
Old 10-17-2006, 11:04 AM   #9
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
http://www.japanparts.com/db/partsli...ddle=1&small=1
on the 2nd page (their javascript/coding foo won't let me give you a direct link) there is Part# 113-068-14471 - 14471 VALVE ASSY. AIR-BYPASS - $57.29.
Not 100% sure this is it, send a PM to Japanparts on here and they should be able to help. jdmpartstx.com gets them from time to time too and now they are local (jdmpartsmd.com doesn't sound as cool. )
Old 10-18-2006, 04:25 AM   #10
Fav Mod: mo boostaz
Thanks Kev!
UPDATE: I feel stupid. I figured out the issue. It was as simple as this: I had ONE boost target too low. Basically, I am trying to spool 20psi @ 3000rpms. I had a boost target at 2600rpms that was too low. As soon as it hit that point, WGDC was pulled away drastically. I raised that point and now all is good. 20psi by 3000rpms easy and holding steadily. Turbo Dynamics clearly showed the issue. I totally overlooked it
t
Old 10-18-2006, 07:56 AM   #11
Car: 01 Subaru WRX STi Sp
Originally Posted by WolfPlayer
I totally overlooked it t
Doh! I always log that value when analyzing a tune...you can see when you start to piss of the ECU when the calibration does not make sense with what can happen with the motor's mechanical components. Most calibrations in the ECU rely on the fact that boost is doing what it has been programmed to do. I have watched tuners chase their tail because they are trying to stabilize their fuel or ignition curves yet they refuse to relate that problem to unstable boost.
Christian.
Christian. is offline   Reply With Quote
Old 10-18-2006, 08:05 AM   #12
Fav Mod: mo boostaz
Originally Posted by Christian.
Doh! ...
Yea, I kicked myself when I saw it this morning. I decided to work on the boost stuff this morning at 10 pts/sec and so I had to rechoose what I wanted to log. AFR, Turbo Dynamics, Boost, Wastegate, and RPM (I can only do 5 items to get 10 pts/sec). I looked and immediately saw it. Grrrr. At least I saw it.
t
Old 10-19-2006, 02:07 PM   #13
I should have picked up on it when you described it. Having had pretty much identical symptoms, though even more pronounced I think, with my SZ55. My surge was so bad if I attempted to fully spool before 4000RPM in fifth gear that my car would go into massive convulsions. I also suspected the BOV at first and did replace mine (to no avail of course). Live and learn.
Old 10-29-2006, 07:58 PM   #14
Car: Slow 05 STi
Fav Mod: Loping Idle
Well looks like it may be time for me to either crush my BPV or get a new BOV. Im cursed by Wolf's posts since everything is eventually happening to me. Heres the situation, I thought I may have had a boost leak which was preventing me from hitting 21~22psi which was my target boost. I finally replaced all my couplers and clamps with silicone ones and t-bolt clamps and what do you know, still can't hit my targets. In 4th+ gears when I go WOT at 2000rpm's I would here a flutter sound thinking it was normal wastegate flutter but now I am thinking otherwise. It only happens at spool and goes away as soon as my boost goes below 20psi. You can see from my log that boost is going up and down and my AFR's are showing it going slightly lean at these points as well leading me to believe that the BPV is not staying shut and releasing pressure back into the intake track. I would have thought that stocker would have been able to hold a little more boost on the stock turbo but guess not. Check it out:
Wolf hows the crush BPV doing? Not sure what I want to do here, either crush it, get a new BOV, or decrease boost and just run more aggressive timing and fuel...
Old 10-30-2006, 01:52 AM   #15
This was the first mod to my Sti.
http://forums.nasioc.com/forums/show...hreadid=454965
TMS
TheMadScientist is offline   Reply With Quote
