Old 10-06-2006, 01:33 PM   #16
Car: 08 Z06 Corvette
Fav Mod: Jack Jack
Originally Posted by RiftsWRX
Be careful!!! Across '04, '05, and '06 I actually use different values!
Well, unless you have some good ideas for those of us with 06s, I can't imagine you would distribute an 06 AVCS map for a non-paying group on a forum
RainMaker is offline   Reply With Quote
Old 10-07-2006, 04:12 AM   #17
Moderator & ECU Tech
Fav Mod: mo boostaz
That's understandable. However, maybe Jorge can talk about WHY he uses different maps. Why do I ask?
The AVCS, Timing, and Fueling maps for the '04, '05, and '06 STI are 100% identical in stock form.
t
Old 10-09-2006, 07:56 AM   #18
Car: Slow 05 STi
Fav Mod: Loping Idle
I am going to guess that just the simple change of the IAM would be enough to change the timing table which in turn would skew his calibrations for fuel, and avcs slightly different for other model years. I would assume this is the case for the different values ever since the 05 buckling problems that were discussed earlier from those previous protunes that had problems.
Old 10-09-2006, 03:36 PM   #19
Car: '02 WRX/'07 FIT
Send a message via AIM to RiftsWRX
t
Because the cars are subtly different. I dunno... SOMETHING changed across model years.
RiftsWRX is offline   Reply With Quote
