Old 09-21-2006, 10:58 AM   #31
I have tried tuning both ways, more fuel+timing, and less fuel+timing.
Personally i like the less than method. But my personal limit on EGT's is a bit skewed from the "norm".
My absolute favorite is A LOT less fuel and timing in between the other two methods. *cough*WI*cough*.
TMS
TheMadScientist is offline   Reply With Quote
Old 09-21-2006, 11:19 AM   #32
http://www.enginuity.org/viewtopic.php?t=686
Mikie liks the less fuel les timing it looks like too.
TMS
Old 09-21-2006, 12:17 PM   #33
Moderator & ECU Tech
Fav Mod: mo boostaz
Damnit. You guys are gonna make me blow my stuff up
Old 09-21-2006, 12:28 PM   #34
Car: '02 WRX/'07 FIT
Send a message via AIM to RiftsWRX
Heh, I think I've dumped over 70 grand at this point... all in the name of "science".
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 09-21-2006, 02:34 PM   #35
Car: Slow 05 STi
Fav Mod: Loping Idle
TMS
Haha I like where your heads at. My issue is that you can only pull so much fuel from the stock ecu (14.7:1) therefore I have resorted to a ~11.2:1 ratio and moderate timing up top and only about a 10.8~9:1 (with a 14.70 listed) at around 3-3.5k. I mean I could turn the injection down but its already set at 7~8psi start and 18psi max running about 21psi. Im tuning AVCS to try and lean it out some more but can't get it much leaner. Also have you noticed that your LTFT go crazy now, I guess its expected with WI though. P.S. I am another one to vote Wolf gets WI *couch again*
Old 09-21-2006, 02:41 PM   #36
I have a 16.5:1 cruise map.
TMS
Old 09-21-2006, 04:32 PM   #37
Car: Slow 05 STi
TMS
Haha, ur running UTEC as well arent you?
Old 09-22-2006, 03:33 AM   #38
Fav Mod: mo boostaz
Back to the original topic.
I changed my DA maps from 10d to 8d and then finally to 6d (with the required changes in the primary ignition map). End result = no change. Still 15.5d at 5800rpms. Oh wells.
I did get my knocklite installed last night. We'll see what that has to say.
t
Old 09-22-2006, 05:38 AM   #39
Car: Slow 05 STi
Hmmm, the STi ecu is so damn complicated. Ill be interested in how the knocklite is reacting.
Old 09-22-2006, 12:53 PM   #40
I'll blow mine up first if you like. I'm going to start leaning up a bit and see what happens. I've already got myself convinced I'll blow the motor sooner or later anyway.
Old 09-26-2006, 10:22 PM   #41
Car: 05 CGM FXT
After finally fully retuning my intake and injectors my car no longer takes full DA either. I have the AFRs close to where they were before in the 11.1 range (my fuel map actually reads close to what comes out of the exhaust now!!! WOO).. The "problem" is I'm down to 13 degrees around 3000 rpm and only going up to 14.5 up around 5500 rpm. Only other thing that has changed is I installed a turbo inlet hose. I'm running the stock airbox again.
When Jorge first tuned my car it would take all 9 degrees of DA when at WOT. I played with the ignition maps a bit and always still got 9s until the injector install and turbo inlet went in.
I'm willing to try this leaning out thing.. =) 12.1? Maybe not yet. I may go for 11.7 though. Interesting thread.
The knocklite set at 3 and 4 sensitivity pretty much 95% matches up with the logs. I would get a flicker and I would see a drop in DA in the logs. I'm still confused as to if the lower DA means actual knock or was it knock prevention.
ZuMBLe is offline   Reply With Quote
Old 09-27-2006, 07:25 AM   #42
Ray: It means it actually heard something it preceived as either detonation, or a harmonic that it inferrered as the onset of detonation.
One thing is for certain. At WOT, any negative value IS detonation.
Old 09-27-2006, 07:37 AM   #43
Car: 05 CGM FXT
Negative value meaning if the DA goes to a value < 0 or in my case where the DA called for a max of 9 degrees and it usually takes 9 but only wants to take 7 now. I never saw a value < 0 during my testing. I've run your map through summer and winter and never had a issue with the car not taking full DA. Even after I played with the ignition map it never had a probablem taking full DA until now.
Old 09-27-2006, 07:43 AM   #44
On a side note... I really like this thread.... It reminds me of the times when I actually had tons of time to post on NASIOC, and really got into the technical nitty gritty on stuff.
Old 09-27-2006, 07:47 AM   #45
Car: 05 CGM FXT
I remember you had a thread on Nasioc about low timing, bad gas and AFRs. I think it was actually a AFR thread.
Mysteries of ECU tuning.
