IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > ECU Tuning & Performance Electronics > Cobb Street Tuner
Old 08-25-2006, 07:42 PM   #1
Car: 05 STi CGM
Fav Mod: Tuning...
Default Theoretical on fueling
So after looking back and forth between the fueling tables of a stock map STi and a highly modified one, I was wondering - if you get the injector scaling and the intake calibration (maf scaling) dead on, then why would you need to change the stock fueling initially - or do you? The stock targets are actually a bit richer than my tuned ones. Can you use the stock fueling map as a jumping off point? Is the major need for tuning because what is indicated in the fuel map is not an actively sought target in OLF i.e. I need to resolve the difference between indicated and desired?
This is all a theoretical question based on trying to learn Street Tuner.
Nixlimited is offline   Reply With Quote
