Old 07-28-2006, 06:33 AM   #1
Fav Mod: Synapse FMIC
Default long term fuel trims in open loop ???
Over time my WOT AFR's have been getting richer and richer, and a simple ECU reset has always fixed the issue. I was looking into it some more the other night (before doing an ecu reset) and I see that I have some big long term fuel trims when at WOT (up to +12.16). The long term fuel trims take my AFR's from high 11's to low 10's.
How can this happen in open loop? I'm guessing that somewhere near the cl/ol transition my MAF scaling is off, and it's just carrying the fuel trims over from closed loop to open loop? Or am I missing something big here?
My tune looks "happy" otherwise with my long term knock learning maps having small positive values all across the table.
Old 07-30-2006, 08:42 PM   #2
Car: 01 Subaru WRX STi Sp
Originally Posted by nhluhr
I think it's mostly gonna be due to an incorrectly calibrated MAF.
Agreed, what intake or MAF housing are you running?
Christian.
Christian. is offline   Reply With Quote
Old 07-31-2006, 02:53 PM   #3
Car: 2005 & 2008 STI
Fav Mod: UR 35R and Hydra tune by Scott Siegel :)
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
Scott Siegel has been fighting this on my car for about 2 1/2 months now. It is more than intake calibration. We have tried several kinds of different intake set ups and none of them corrected the problem. Seems to mostly occur on mid/late 2005 year models...????
This is a Cobb and Ecutek issue. We have seen cases with both. My car won't go into open loop till 3V at the MAF instead of 2.5V like its supposed to. Not sure what the answer is at this point.
JDM-STI is offline   Reply With Quote
Old 07-31-2006, 05:36 PM   #4
I'm running the perrin bigmaf with the perrin rotated mount intake. My intake calibration seems dead on but I tried adding a couple % on the top end to see if it makes a difference.
I've been wondering if this is another goofy byproduct of my removing the rear o2. I really need to get another bung welded on.
Old 07-31-2006, 06:14 PM   #5
Nope! I still have my rear O2.
I run the Perrin big MAF and my intake calibrations were dead on as well. Seems to be some type of flash issue.
Old 07-31-2006, 06:54 PM   #6
It happens because patterns of correction noticed by the ECU in closed loop are migrated to your open loop fueling. That is why a reset fixes it. The ECU assumes that if has to keep adding, say 10% of fuel in closed loop to hit 14.7, that you are probably running leaner in open loop as well and this is added to your open loop fueling.
Merchgod is offline   Reply With Quote
Old 08-01-2006, 08:34 AM   #7
Moderator & ECU Tech
Fav Mod: mo boostaz
I agree. OEM ECUs are notorious for applying a learned fuel correction in open loop based off of extrapolation. People often think that open loop means no correction. That is just not true. I remember hacking the GM code back in 2000 to remove this 'feature'. Open loop should be open loop for us hotrodders . However, in no way is that guaranteed with a stock ECU.
Jay, are you still running around without a rear O2 sensor? As we have discussed here, the rear O2 definitely affects AFRs.
t
Old 08-01-2006, 08:50 AM   #8
Car: 05 CGM FXT
I thought I was going crazy or my wideband was off! I saw this also. When I first installed my wideband and ST with my protune map I was seeing afrs in the 11s which was good. Then later on it went in to the 10s at WOT and sometimes 9s! I recalibrated my wideband but I also reflashed a basemap then and it brought everything back to the 11s. I have a 05 FXT. Hmmm..
ZuMBLe is offline   Reply With Quote
Old 08-01-2006, 03:25 PM   #9
t
Yep, I'm still running without the rear o2. I'm pretty sure that's what's killing my gas mileage. I'm going to have the bung welded on at the same time as some other work (ewg dump tube , tial bov flange, blow thru maf, etc). It'll be a couple more weeks.
There's lots of good info in this thread. I'll datalog in a couple days to see what's happening with my long term fuel trims, and if my last change made a difference.
Old 08-02-2006, 05:59 AM   #10
Car: Slow 05 STi
Fav Mod: Loping Idle
Trader Rating: (12)
BTW don't use a mechanical fix on your rear o2 either. I got a new bung welded for my wideband but it still stays at 13.9 during closed loop but for a much shorter time than when the o2 sensor was just ziptied. It seems like something that was changed in Cobbs firmware when they upgraded since I have read that others didn't see an issue with it until it was upgraded. I think maybe we all need some fresh maps from Cobb like Jorge stated with the problems he has been having with 05's. I know I am going to be reading my ROM tomorrow when my Tactrix cable arrives and say hello to protuner features.
Old 08-02-2006, 07:33 AM   #11
Fav Mod: mo boostaz
Affirmative. Been there, done that It's a great solution. Also, the tactrix + ECUFlash is SOOOOOOOOOO much quicker than flashing with the AccessPORT.
t
Old 08-02-2006, 08:10 AM   #12
Car: Slow 05 STi
Trader Rating: (12)
Oh really, thats a VERY good thing to know since I had no idea what to expect. I got a couple of questions though, I have noticed when I rescale a table in Enginuity and then open it in ecuEdit, it has completely changed. I actually thing I prefer ecuEdit b/c it has access to more tables the enginuity only has in debug mode meaning it is untested. Also did you unmarry your AP/ST before you flashed? I don't want to comprimise losing the license of the AP by trying to change one parameter like IAT timing retard.
Old 08-02-2006, 11:43 AM   #13
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
t
I know my old civic applied long term correction to the open loop stuff. But I thought the STi didn't do this and the WRX did.
Am I wrong?
Old 08-02-2006, 03:51 PM   #14
Jaygoesfast and Nhluhr, at what MAF voltage are your cars going from closed to open loop. Mine has a bad negative fuel trim correction in closed loop and once it learns this correction it won't go into open loop until 3 volts instead of the desired 2.5 volts. We have been fighting this for a while with out any solution so far. So I want to compare mod set ups to mine and whatever other info you guys have to offer.
Old 08-02-2006, 04:16 PM   #15
Stupid question, but how can I tell when the car switches from closed loop to open loop ? I always assumed that high rpm @ wot was open loop, but never knew how to determine which mode it was in.
