| | #16 | |
| Platinum Member Car: 2005 & 2008 STI Fav Mod: Scott Siegel Tuning!!! :D Location: Columbus, GA Posts: 2,017
IWSTI Addict since: Mar 2005 Trader Rating: (11) | Quote:
| | #17 |
| Spec C Club
Car: Blue 05 STI Fav Mod: 4th gear wheelspin Location: Upstate NY Posts: 2,095
IWSTI Addict since: Nov 2004 Trader Rating: (0) | I guess you could watch for when your short term fuel trims go to 0 (+0.39). I'll look through some old datalogs and see if I can find any correlation. |
| | #18 | |
| | #19 |
| Spec C Club
IWSTI Addict since: Nov 2004 Trader Rating: (0) | From looking at some of my datalogs, it looks like my car usually switches from closed loop to open loop at 2.5v, but occasionally it's higher up to around 2.9v. |
| | #21 | |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,759
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
t | |
| | #22 |
| Spec C Club Car: Slow 05 STi Fav Mod: Loping Idle Location: Chewy's Garage Posts: 1,877
IWSTI Addict since: Mar 2005 Trader Rating: (12) | Excellent, I just didn't want anything to 'happen' like ecutek and lose my ap license and etc. I def. need to modify my intake temp. retard b/c it is essentially making my alky injection pointless right now in the rediculous VA heat wave. |
| | #23 |
| Spec C Club
IWSTI Addict since: Nov 2004 Trader Rating: (0) | Interesting - this makes sense although I'm not entirely awake yet. My maps were spot on when I was running a mix of race gas and 93, the problems did seem to start when I switched back to straight 93. Some of the local gas stations say "10% Ethanol" on the pump while others don't... most likely though, they all get their gas from the same place. My wideband died from all the leaded race gas so I won't be able to confirm this for at least a few days... I'm not touching anything on my tune till it's fixed. edit: I probably never realized the afr change in OL because I'm spraying so much methanol in Last edited by jays05; 08-06-2006 at 05:18 AM. |
| | #24 |
IWSTI Addict since: Mar 2005 Trader Rating: (11) | Very, very interesting. Anyone know how much of our fuel in the southeast contains E10? GA particularly in my case. I've been searching on the net without very many answers. |
| | #25 | |
IWSTI Addict since: Mar 2005 Trader Rating: (11) | You said in an earlier post that you car was going into open loop at 2.5 volts and sometimes 2.9 volts at the MAF. I would be interested to know if you were switching at 2.5 volts like you are supposed to on the race/93 map and your 2.9 volt occurances are happening on your straight 93 maps... This might explain your fuel trim problems as well. I run a 93/meth map full time on my car, so it might explain some things on mine as well. I haven't had the chance to get SS's thoughts on this yet. Thanks for the info Nhluhr. ![]() Quote:
| | #26 |
| Spec C Club
IWSTI Addict since: Nov 2004 Trader Rating: (0) | It was on straight 93+meth... basically what I did was I took a really big datalog (around 1mb as a .csv file), pulled it into excel, sorted by maf voltage, then watched where the short term fuel trims tapered off to 0. There were a handful of log entries above 2.5v MAF with a short term fuel trim not equal to zero, but the majority were at/below 2.5v. I haven't dug into it much further than that. |
| | #27 | |
IWSTI Addict since: Mar 2005 Trader Rating: (11) | What happens now if you have to fill up somewhere that doesn't have E10? Quote:
| | #28 |
IWSTI Addict since: Mar 2005 Trader Rating: (11) | MAybe my situation is different than you guys. My fuel trims are perfect, at or near 0 while cruising as long as my MAF voltage stays below 2.5 volts. When you get part throttle and the MAF voltage rises my short and long term trims start a negative correction at 2.5 volts and keep making the correction until 3.0 volts when the car finally goes into open loop. No matter what we do, the car absolutly refuses to go into open loop until 3 volts. Last edited by JDM-STI; 08-10-2006 at 06:49 PM. |
| | #30 |
| The Next Petter Solberg Car: 08 Z06 Corvette Fav Mod: Jack Jack Location: Portland, OR Posts: 882
IWSTI Addict since: Oct 2005 Trader Rating: (3) | I think the sad secret is that most tuners have no idea. I've had this very conversation with tuners after they said "theres no learning in open loop"... and they were unaware of the typical integration of closed loop learning into open loop values in most modern PCMs This ad is not endorsed by this member. Please register or login to hide this ad. |
