Old 07-26-2006, 07:54 PM   #1
Car: 05 CGM FXT
Default Boost Spiking?
Is a spike ever acceptable? Of course its best if we never saw a spike. But if it happens and the AFRs stay stable, is it okay? If the AFRs do stay stable and there is a spike what exactly happens to the engine? I have a knocklite and there is no knocking from the spike.
ZuMBLe is offline   Reply With Quote
Old 07-27-2006, 05:09 AM   #2
Moderator & ECU Tech
Fav Mod: mo boostaz
I would say it depends on how big the spike is. Be specific. What is happening?
t
Old 07-27-2006, 07:33 AM   #3
Car: 05 CGM FXT
When I got on the throttle at 4k in 4th and 5th I see spikes up to 20psi when the boost target maps call for 18.6 (I'm slowly raising it to see how the car reacts). The spike happens for a second or less.
I've since lowered my WGD Low table a bit in hopes the ecu will learn better. I had the table set so the values were 2-3% apart but now I have it set so they are 5-6% apart.
t
Old 07-27-2006, 09:52 AM   #4
Car: Slow 05 STi
Fav Mod: Loping Idle
At lower rpm's (under 5k) it is best to set the WGDC's about 10% from the high map. It will only get worse in the winter when it is cooler out and you will spike even more. Mine are lower until about 5200rpm when the are back to 5% within the high map.
Old 07-27-2006, 11:28 AM   #5
Car: 05 CGM FXT
Nice tip. I'll whip up a new realtime with those settings. ST makes these things so easy..
