Old 07-07-2006, 04:18 PM   #1
Car: 05 Subaru WRX STi
Fav Mod: Exige
Default Injector Help
Hello,
I installed a set of JEC 720cc injectors today. I used a scale of 3730 with Wolf's posted latencies from WitchHunter. The car starts and idles perfect but my LC1 says it is idling at 12:1. I wonder if the wideband sensor is busted. Also, I have an APS 65mm CAI and thought I had tuned it well but maybe not. My immediate trims were crazy high 24's or so. The long term trims were at ~1.9. Any help with this would be greatly appreciated.
Thanks,
Brian
sti752 is offline   Reply With Quote
Old 07-07-2006, 04:36 PM   #2
Fav Mod: when it's not blown up
The latencies recommended by Cobb for the Jecs 730cc injectors are 4.62, 2.35, 1.27, 0.88, 0.67 and the Nismo 720cc injectors are 4.68, 2.38, 1.29, 0.92, 0.67 (not sure which one you actually have)
Not sure if this jives with the numbers that came from witchhunter, but I can tell you that the witchhunter numbers for the pe850cc injectors did the same thing and the recommended latencies from cobb worked great for me.
Old 07-07-2006, 05:17 PM   #3
Fav Mod: Exige
Thanks Jay. The Cobb JEC latencies you gave me worked perfectly. I guess I had way too much latency at ~14 volts and the injectors were firing too long.
