Old 06-27-2006, 04:35 PM   #1
IWSTI Addict since: Oct 2004
Default Rescaling Load Question
I have not rescaled my maps as of yet. For the first time (when logging) last night I went above the std 2.75, think I got up around 3.1 tops. I am planning on rescaling the maps but have a question about what it does when it goes off the scale. My assumption is that it uses the values in the last colum for anyting greater then it. Is this correct.
Ok so when I go to rescale my maps I was planning on using the values from the current final column (2.75) for the values in higher rescaled columns as a strarting point since my AFR's were fine during those runs and I did not have any knock.
roybfr is offline   Reply With Quote
Old 06-27-2006, 04:50 PM   #2
Car: 2004 STi
IWSTI Addict since: Feb 2004
That is correct. It uses the values from the last column.
