Old 06-21-2006, 03:49 PM   #1
Car: 01 Subaru WRX STi Sp
IWSTI Addict since: Aug 2005
Default Please measure the ID of your MAF housing when you get some time...
Would you mind measuring the inside diameters (in milimeters) of your aftermarket intakes. I am compiling a database of the various aftermarket intakes (MAF housings) and setting up an equation that will assist you with the generation of a global Intake Calibration multiplier so that you can more easily start your vehicle when using the StreetTUNER software to make a base calibration. This is what I have thus far...
Global Intake Calibration Multiplier 3.14159265358979 = pi
This calculation should only be used to assist you in the generation of a base map so that you can start your vehicle which has a MAF housing other than stock installed on it. Tuning your Intake Calibration table must be performed after you have started your vehicle. When switching your intake to an aftermarket you can use this multiplier to glabaly modify your Intake Calibration table based on the difference in diameters (surface area) between the two intakes, follow Step 1) below
66.5 Step 1) Enter the inside diameter for your stock MAF housing, choose from below list.
70.0 Step 2) Enter the inside diameter for aftermarket MAF housing.
1.0526 Step 3) Your Global Intake Calibration Multiplier
Step 4) Copy (CTRL+C) the data from cell B10 from this worksheet, highlight all of the lower cells in the Intake Calibration table, press the "m" key, then paste (CTRL+V) the copied value into the dialog box asking for a floating point value then press the Enter key.
Surface Area of a Sphere = 4 pi r 2
Intake Diameter Surface Area
66.5 mm ~ ID of stock 2002-2005 WRX MAF housing
66.5 mm ~ ID of stock USDM STi MAF housing
70.0 mm ~ ID of stock 2005+ Legacy GT MAF housing
65.0 mm ~ ID of APS Cold Air Intake System - 65mm, P/N APSWRX-HFA/01
70.0 mm ~ ID of APS Cold Air Intake System - 70mm, P/N APSWRX-HFA/02
~ ID of APS Pod Air Intake System - ??mm, P/N APSWRX-PAC/01
This is all set up in Excel and OpenOffice (freeware) so it has functional formulas and will look better.
Thanks,
Christian.
Christian. is offline   Reply With Quote
Old 06-21-2006, 04:47 PM   #2
Car: 2004 STi
IWSTI Addict since: Feb 2004
The Apexi short ram has an inner diameter of 70mm. However it also comes with a piece that goes in front of the MAF to direct air towards it. So if you put that in, all bets are off as far a quick diameter based formula.
Old 06-21-2006, 06:10 PM   #3
Car: 2005 & 2008 STI
Fav Mod: Scott Siegel Tuning!!! :D
IWSTI Addict since: Mar 2005
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
Injen CAI is 65mm and the Perrin big MAF is 76mm.
JDM-STI is offline   Reply With Quote
