Old 03-15-2007, 08:10 AM   #91
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
I reset the ECU and things are now targeting stoich.
Old 03-17-2007, 04:52 PM   #92
Car: 07 WRX STi
Interesting, I wonder if some of my problems with my AP Stg 2 on my STi is because I have the old fashion 02 sensor mod(using spark plug defoulers) still on my dp. Maybe this is making my car run too rich....?
Ooie is offline   Reply With Quote
Old 03-28-2007, 10:53 AM   #93
Fav Mod: Junior Tuned
Send a message via AIM to boostedrex05
i dont mean to be off topic even though im still talking about a wideband, does anyone know what the best way to hook up a plx m-300? if so please pm me im lost.
boostedrex05 is offline   Reply With Quote
Old 03-28-2007, 11:14 AM   #94
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
With the stock harness that they supply with the kit?^^
Old 03-28-2007, 09:03 PM   #95
lol i wish it was that easy they say they want you to wire it as close to the ECU as possible. thats the IG power and ground and the Narrowband wire and wideband wire. witch is the gray and the white. then you must wire a resistor to top everything off. and the 2 capacitors.
All I really need to know is, If i should find the pin for the 02 sensor on the wire harness to the ECU plug or just run the wires to the stock sensor. and run the normal power and ground to lets say the cigat lighter since my car is a none smoker anyhow.
Old 03-29-2007, 07:15 PM   #96
Car: LandShark STi
Fav Mod: GT40R
Send a message via AIM to TheRipler Send a message via Yahoo to TheRipler
Originally Posted by R4ND0M_AX3
analog1 yellow
Did you make any changes to the LC-1's output programming for analog1 out?
I'm seeing the same thing. My stock rear 02 is hanging in open air. If I even touch the throttle, idle AFRs on the LC-1 drop to 13.4-13.5 for 20-30sec before returning to 14.7. It bugs me that it's dumping extra fuel in there when it isn't needed, and I'd like to get it straightened out.
TheRipler is offline   Reply With Quote
Old 03-29-2007, 08:16 PM   #97
no. analog output 1 is preconfigured for a typical narrowband signal.
Old 03-31-2007, 07:49 AM   #98
Fav Mod: when it's not blown up
Analog1 yellow to D25 on the ECU connector B137. At the ECU the signal wire for the rear O2 sensor is white. This is for a 2005 US STi.
I already had the wires inside the cabin so I decided to hook up at the ECU. I had wanted to get a dead sensor and use its connector at the fatcory location. I don't know what color the wire is down there.
Awesome, thanks for that. My car doesn't have a rear o2 and I had all the AFR problems mentioned in this thread. I really didn't want to buy a new rear o2 and have a bung welded... I'll try this out once my car has an engine in it again
jays05 is online now   Reply With Quote
Old 12-21-2007, 02:28 AM   #99
Car: 03 mbp gga
Fav Mod: 12.9 / 105+
Send a message via AIM to ride5000
Default Re: Do NOT remove your rear O2 sensor
Originally Posted by jfitzpat View Post
The reason I don't 'see it' is it is actually very, very hard for an ECU to make meaningful fuel adjustments from a post cat sensor. There are tons of SAE, etc. papers on the subject. I've also done work on measuring cat efficiency on the fly myself.
i know i'm late to the party, but i disagree strongly with this statement.
ride5000 is offline   Reply With Quote
Old 02-21-2008, 09:48 AM   #100
Fav Mod: APS 3" turboback
Arrow Re: Do NOT remove your rear O2 sensor
I was doing the same thing. I took off my mechanical cell fix (defouler) and the car seems to run better. It hits boost much quicker; at least it seems that way.
I would take your's off, as COBB OTS map was obviously made without the defouler's in place.
jwild is offline   Reply With Quote
Old 02-21-2008, 12:16 PM   #101
Car: 07 WRX STi
Protune did away with all problems
Old 02-23-2008, 05:27 AM   #102
i called cobbs and they said u can pull out the sensor and zip tie it. They said only problem is i might damage my sensor due to road debris but i live in new orleans where salt is'nt a problem.
my supra downpipe didn't have a place for a sensor so i had it zip tied to my tranny brace for 3 yrs. when i went with 4 inch exhaust i put it back in and it still worked surprising.
My car even with the o2 sensor plugged in will go to 13.9 for a couple of seconds and then eventually idles @ 15:1. In all honestly it isn't a big deal.
sidwin is offline   Reply With Quote
Old 03-08-2008, 10:29 PM   #103
Car: 02 wrx
Any problems with wiring the analog out to the rear 02 signal yet?
I have been having this same issue for a year now.
SmobySport is offline   Reply With Quote
Old 03-10-2008, 09:12 AM   #104
still works. 60K+ on the car now.
