Old 06-19-2006, 05:05 PM   #16
JSK
Car: White 2004 STi
IWSTI Addict since: Mar 2005
If someone has protuner and can change the map I would not mind making a small donation.
Also, that offer stands for a ST map for a 04 that is equal or better then the Cobb stage 2 93 that came the AP. The ST base map is made for 91 octane and I'm not sure why they did not come up with 93 map. I always run 93 plus an octane booster w/ MMT that has proven to rise the octane level about 2-3 numbers (not points) - so I'm really usually at 95
Originally Posted by crystal_Imprezav
You need a Protuner to do that.
JSK is offline   Reply With Quote
Old 06-19-2006, 07:00 PM   #17
Car: Slow 05 STi
Fav Mod: Loping Idle
Trader Rating: (12)
I would say use Wolfplayers rescaled stage2 map. It is a great place to start and I think it is modified for 93 (maybe, not sure). The rescaled loads are very helpful since I know on my car I hit 3.2 load on 93 and 3.4_ on racegas. As for the oct. difference, for 95 I would probably shoot for the same timing values I listed above and if your car isnt reducing the KC at all, give the PI small increases until you are satisfied. My butt dyno work great for this, haha. If you send me some screen shots of your map, and any recent logs on that map, i'm sure I could give you some advice and maybe tweak it for you a bit in excel.
Old 06-20-2006, 05:45 AM   #18
Moderator & ECU Tech
Fav Mod: mo boostaz
IWSTI Addict since: Jun 2004
The rescaled map has NO tweaks! It is just a stock Cobb Stg 2 map that has been rescaled
I might put together an ultra-tweaked map with new AVCS, new timing, etc. We'll see.
t
Old 06-20-2006, 03:07 PM   #19
Car: Slow 05 STi
Trader Rating: (12)
^^ Haha sweet. We can do some map trading, since now I can varify my results. What kinda of changes would you make to the AVCS? I don't believe my was changed at all. I am still not sure what tweaking this table will do. Any advice or info on it?
