Old 05-26-2006, 12:25 PM   #1
Car: 04 Black STI
Send a message via AIM to reid-o Send a message via Yahoo to reid-o
Default Boost Limit Question
The concensus seems to be that the ECU can only read up to 18.5 psi, so if that's the case, then by raising boost limit past this, am I sort of disabling fuel cut altogether?
Or does it calculate by subracting 14.7 from absolute?
Sorry if this sounds like a noob question, but it just sort of occured to me now.
reid-o is offline   Reply With Quote
Old 05-26-2006, 01:36 PM   #2
Car: 2005 WRB STi
Fav Mod: roadhead
Send a message via AIM to overdose Send a message via MSN to overdose Send a message via Yahoo to overdose
it subtracts
overdose is offline   Reply With Quote
Old 05-27-2006, 04:28 PM   #3
Yeah. The ECU knows the real boost (up to the MAP sensor limit, don't recall what that is, but it is over 22psi I believe). The 18.42 limitation is just with the protocol used to read relative pressure via the OBD-II port.
Old 06-01-2006, 07:51 AM   #4
Fav Mod: Dyslexia
Trader Rating: (13)
Pretty sure it's 21. Mine started wigging out past this, also what I have heard from others.
Old 06-01-2006, 08:08 AM   #5
24.8psi is the sensor limit, once you start to get close to the limit the reading will start to get funky.
TMS
TheMadScientist is offline   Reply With Quote
