Old 03-18-2006, 03:43 PM   #1
Car: '04 WRB
Fav Mod: A working ECU...
Unhappy Help!! Car won't start...
Here's the rundown:
Tried reflashing a new basemap at work (street tuner), kept losing connection with the ECU mid-flash. Had to turn the car off, back on, same prob. Eventually was able to reflash the original map I was running before...then the car wouldn't start. Called Cobb, they said it sounded like a battery problem. I thought the same and already had a battery on the way. New battery and the car started fine, drove home...
Figuring with a good (stock) battery I was good, I tried reflashing the same basemap that couldn't flash before. Again it lost connection with the ECU just before it was finished. Tried again after turning car off, back on, now can't connect at all. Tried disconnecting the battery to do a 'hard' ECU reset, nada. Trickle charged the battery for a long time...still nada.
Normally when the key is turned to 'on' I hear the fuel pump prime, etc. Now I don't - instead a fast clicking from the engine bay near the alternator, and some clicking noise from the rear (likely the pump?). When I try to start the car it turns over strong, but won't start. Now I can't do anything with the Accessport - can't switch maps, revert to stock, flash a basemap, etc. Nothing. (green test mode connector was connected for the appropriate actions).
I'll call Cobb on Monday...but this is my daily driver . Any thoughts??
Sounds crazy, but is it possible that a bad mapped ruined my ECU? This was a map I ran successfully for months, but just made a few small changes.
THANKS!
Old 03-18-2006, 04:05 PM   #2
wdb
dances with roads
Since the car turned over strongly it's unlikely that it is the battery itself that is the problem. I would inspect all of the connections to the battery, at both ends. And if you are hearing clicking under the hood I would try to determine the source. Beyond that I don't know what to say besides "Christian, are you online?"
Good luck!
Old 03-19-2006, 01:13 PM   #3
Car: '04 WRB
Yeah, I didn't think this would be an easy one. I'm hoping to talk with Christian on Monday...otherwise I had better practice hitchiking
Old 03-19-2006, 01:34 PM   #4
Car: 06 Subaru WRX STi
Fav Mod: My right foot...
Ouch, that sucks! Did the Cobb connector was firmly plugged to your car's port during the first flash? I would unplug the battery and leave it that way overnight until you speak with Christian on Monday. Maybe the ECU eventually will clear out itself...? Keep us updated and hopefully it will not be something major.
pantag is offline   Reply With Quote
Old 03-19-2006, 02:56 PM   #5
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
Can you connect to the ECU with your ST?
STirish is offline   Reply With Quote
Old 03-19-2006, 03:44 PM   #6
Car: '04 WRB
No deal, this ECU won't talk to anything. When I click on 'live tuning' it can't connect...
So here's my new daily driver, at least there's no rain in the forecast for the next week. This thing has been sitting since November, battery still connected. Sure enough, starts right up. Modern technology
Old 03-19-2006, 03:52 PM   #7
Car: 06 STi
Fav Mod: Espelir JGT500 cat-back
At least you have a nice ride for the time being. Hope you get things straightened out.
johnson81 is offline   Reply With Quote
Old 03-19-2006, 04:19 PM   #8
That does not sound good. I'm not sure exactly what may have caused the poor connection, but the behavior you describe sounds like a frozen ECU.
Old 03-19-2006, 04:37 PM   #9
Car: WRB 2005 STI 404whp!
Fav Mod: COBB AccessPort
Send a message via AIM to dexterous
Did you let your car sit all night with the battery disconnected?
dexterous is offline   Reply With Quote
Old 03-19-2006, 05:13 PM   #10
Car: '04 WRB
Yes I did, all night.
So if Christian can't come up with any brainstorms on Monday, the options are to trailer it to a dealer or XX Tuning...or just pickup a used ECU and assume that's the problem. I'd really hate to be missing something stupid and end up buying a new ECU, but on the other hand I *think* I've tried everything possible...
Old 03-19-2006, 05:16 PM   #11
Try to find someone in your area w/ an '04 and swap ECUs.
Old 03-19-2006, 05:49 PM   #12
Fav Mod: Agile protune
When I last tried to switch base maps (after dark, after a long day at work), it sounds like (based on your description of the sounds,etc) the same thing happened to me...scared the **** from me. When the weird sounds began, i freaked and quickly disconnected the ap, etc. After a full night's sleep, I tried again. The problem was that I was choosing the wrong menu item from the ap menu screen. There are 2 items that sound similar, one is something like "switch base map" and the other is something like "flash new base map". The one that was the correct choice was near the bottom of the menu, near (approximately) choice 7 or 8 ( i think it was the "switch map" option, as opposed to the "flash new map" or whatever the actual name is). Even though they both sounded like correct choices, my incorrect choice was apparently the exact reason why I was getting the "cannot communicate with ecu" message, as well as the strange sounds, sounding exactly like what you described. Try switching maps using the menu choice (relating to base map reflashing) that u did not choose before. I apologize for the lack of precision in my explanation, but I am almost positive that what u described happened to me, and i can't remember the exact menu choice names to which i am referring. I had the phone in-hand ready to call cobb when I figured out the problem. good luck!
005sti is offline   Reply With Quote
Old 03-19-2006, 06:21 PM   #13
Its a good thing that you have an 04. 05s have the immobilizer which is a huge pain in the but if your kill your ECU. I second the swap ECU's with a friend suggestion.
Old 03-20-2006, 05:00 AM   #14
Car: '04 WRB
Thanks for the help 005 STi. It sounds like you were confusing realtime maps (switch map) and base maps (load new basemap). I don't think I'm so lucky...I can't even read CEL's. I did find a used ECU if it comes to that...
Thanks -
Old 03-20-2006, 06:00 AM   #15
good luck.
