Old 02-21-2006, 08:11 PM   #1
Car: 05 Subaru WRX STi
Fav Mod: Exige
IWSTI Addict since: Jul 2005
Default O2 sensors
Which stock O2 sensor is needed for closed loop functionality? I have an LC-1 ready to go as soon as I receive my downpipe and was just wondering about the stock sensors and their purposes. Thanks.
sti752 is offline   Reply With Quote
Old 02-22-2006, 07:30 AM   #2
Car: 2004 STi
IWSTI Addict since: Feb 2004
The 02 sensor used for closed loop is the one in the header just before the uppipe. I believe the only purpose of the 02 sensor in the exhaust is to detect bad cats (not 100% sure about this though).
Old 02-22-2006, 09:12 AM   #3
Fav Mod: Exige
daemon,
thanks for the input but does anybody know for sure? I know the Cobb downpipes come with two bungs, one for WB02 and one for one of the stock O2 sensors. Is that the one that is required for closed loop operation? Anyone? Thanks.
Old 02-22-2006, 09:17 AM   #4
Car: 2004 STi
I know for sure that the 02 in the exhaust manifold before the upipe is the closed loop sensor. What I'm not 100% sure about is if the only purpose of the 02 past the cat is just to make sure that cats are working. Neither sensor in the the downpipe is for closed loop.
Old 02-22-2006, 09:36 AM   #5
Fav Mod: Exige
daemon,
oh, I misunderstood you. Sorry about that. Thanks for your help.
Old 02-22-2006, 01:19 PM   #6
Car: 2004 STi
No problem. I wasn't very clear the first time.
Old 02-22-2006, 05:53 PM   #7
Fav Mod: Exige
Okay so now that I have that issue understood thanks to daemon. Does any body else know what purpose the O2 sensors in the stock downpipe serve (i'm guessing emissions)?
Also, what downpipes do the rest of you streettuners have and do you have WBO2? For the WBO2 where do you put it and do you keep it in there all the time or just when tuning? Just Curious.
Thanks
Old 02-22-2006, 06:06 PM   #8
Car: 2004 STi
I have a Cobb downpipe with cat. I use the LM-1 wideband which I put in the bung immediately after the turbo. You don't want to tune off a wideband behind a cat as it will skew your results a little. It can be done, but since you have a pre-cat bung, that's were it should go.
I only have my wideband in when tuning. Mainly because I have that old (e.g. big) Innovative controller box which is annoying. If I had the self contained gauge version I might leave it in. Not sure.
Old 02-22-2006, 06:58 PM   #9
Fav Mod: Cobb StreetTUNER
IWSTI Addict since: Jul 2004
I have a catless invidia DP. Innovate LC-1 is where the stock rear sensor was. I intend to keep it this way. I use the XD-1 to keep me informed.
