Old 01-19-2006, 05:03 AM   #16
Car: BMW M5 993 Turbo
^^^^ Wow Defiant pretty much described every issue I currently have.
I have ECUTEK so hopefully Tony can solve the problems for me as I don't feel I should have to run a Cobb AP to do it. I am guessing he was able to do it with the Cobb AP because he has more experience tuning with that vs ECUTEK.
aspensti05 is offline   Reply With Quote
Old 02-08-2006, 09:14 AM   #17
Originally Posted by Defiantspaz
If you are driving at a steady pace and then lightly back off the trottle sometimes my car would shutter violently back and forth, kinda like bucking on a start only it is at 75MPH. Bad Idle, poor fuel milage and the shutter were all of the issues that I had. Switching to the Cobb AP has so far solved all of these drivability problems for me.
Well this was gone right after Tony tuned my car on the 28th, but it came back. I tried adjusting my APS valve and checked all the FMIC hoses for leaks. I've got the crazy idle again and the shudder/bucking is back.
After re-reading your post, it seems I need to switch to Cobb to fix it? I shouldn't have to switch EM to fix something like this. I doubt it is a limitation of ECUTEK, possibly the tuner? IE Tony is a better Cobb tuner than ECUTEK tuner perhaps?
Old 02-08-2006, 07:54 PM   #18
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
Originally Posted by aspensti05
TGV deletes have nothing to do with this.
I have the same turbo AND the same injectors AND Tony from XX tuning tuned my car AND I have the same idle problem that 1FastSti has.
I have seen the Perrin injectors being off from each other as much as 6-9% in flow. Not a good thing at all.
STirish is offline   Reply With Quote
Old 02-09-2006, 03:48 AM   #19
Not sure how this relates as 1FastSTi and I both have the Power Enterprise injectors not Perrin
Old 02-09-2006, 07:02 PM   #20
Whoops, could have sworn I read Perrin injectors in his mod list, Sorry.
