Old 01-12-2006, 07:17 PM   #1
IWSTI Addict since: Apr 2004
Default Anyone running a Perrin Big MAF???
If anyone is, your settings for the ST would be GREATLY appriciated!
1FastSTi is offline   Reply With Quote
Old 01-14-2006, 08:01 AM   #2
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
IWSTI Addict since: Sep 2004
The basics:
1. Find a mustang dyno for an hour.
2. Open the dash board with load, STFT, and LTFT
3. Set a fixed RPM on the dyno.
4. Steady the car on a load point and let the STFT stabilize. (Watch engine oil and water temps, keep them in check!!!)
5. Modify the intake calibration until the LTFT is close to 0 (+-1-2%) (Let the STFT stabilize between changes)
6. Move to the next load point on the intake cal map and goto #4
STirish is offline   Reply With Quote
Old 01-14-2006, 08:54 AM   #3
Car: Honda Fit
IWSTI Addict since: Aug 2004
Send a message via AIM to XfactorSTi
it should not be hard to calibrate it with bigger injectors, they will almost cancel eachother out with the stock fuel map, adjustments must be made though.
XfactorSTi is offline   Reply With Quote
Old 01-14-2006, 09:36 AM   #4
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
IWSTI Addict since: Jul 2004
They only 'cancel' each other out if you have the perrin modded stock injectors.
Old 01-14-2006, 10:26 AM   #5
Originally Posted by STirish
The basics:
Thanks for the tips. Unfortunately there isnt a Mustang dyno anywhere around me.
Does this make sence? Say if i take the measurment of the stock intake and compare it to the Big MAF. And then rescale the intake calabrations accordingly compared to the stock intake.
IE: Stock intake size is: lets just sat its - 2"
Big MAF intake is - 3:
Take that ratio and apply it the the intake calabration table.
It makes sence that it would work however im still uncertain.
Old 01-16-2006, 08:44 AM   #6
Originally Posted by 1FastSTi
...Does this make sence? Say if i take the measurment of the stock intake and compare it to the Big MAF. And then rescale the intake calabrations accordingly compared to the stock intake.
I don't think that's gonna work. You might be able to get away with fixing a couple of points on the low side then fix a couple up top. Then (I think wolfplayer did this) use the top and bottom correction factors to scale the original numbers. I think the amount of correction will be different as you flow more air. But I haven't done it so don't listen to me.
Old 01-17-2006, 08:22 AM   #7
It is a ratio, but a ratio of the cross sectional area of the MAF. I think that should get you close, but you're still going to need tuning. Air flow around the MAF is probably not optimal with what intake you are running.
My little disclaimer: I'll say it now, if you are not 100% confident in what you are about to do, don't do it. Take the intake off and go to a professional. You could seriously damage your car.
Old 01-17-2006, 05:21 PM   #8
I am going to just run a stock size short ram intake to drive to the tuner and let him work his magic.
Old 01-17-2006, 06:24 PM   #9
Car: Was: 05 Aspen White
IWSTI Addict since: Jan 2005
It is not a linear relationship.
http://www.pdxtuning.com/nasioc/BigMafvsStockMAFVol.gif
RSVCHAD is offline   Reply With Quote
Old 01-17-2006, 06:28 PM   #10
Originally Posted by RSVCHAD
Thanks for the chart, yea for the most part im going to leave it to my tuner to get it right.
