| Professional STI Racer | I have been playing with the DA-A and DA-B tables lately. I have been playing in the low load columns. Something I have noticed is the DA-A table is used when the coolant temp is below ~180F and the DA-B table is used when the collant is over ~180F. This is on an 04 Sti. Has anyone else seen this behavior? Again this is all in the low load columns, no boost. TMS This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,759
IWSTI Addict since: Jun 2004 Trader Rating: (6) | TMS, I just got finished running this test. DA A was set to 3 everywhere and DA B was set to 1 everywhere and DA C was set to 0 everywhere. My Dynamic Advance followed DA A completely. To clarify, the Dynamic Advance followed DA A independent of coolant temperature. This included taking logs well past once the coolant temperature reached 180d. Are you sure that your learned knock advance was zero across the board? What was your IAT? My IAT was between 68 and 72 the entire time. t |
| | #4 | |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
Why am I suggesting this compromise? Because it will still allow your car to have that extra safety margin built-in that is dependent on the IAM (DAM). t | |
| | #6 | |
![]() t | |
| | #7 |
| Spec C Club
Car: Blue 05 STI Fav Mod: 4th gear wheelspin Location: Upstate NY Posts: 2,095
IWSTI Addict since: Nov 2004 Trader Rating: (0) | Gimme, I am sick of having to copy-paste the DA-A map to DA-B and C. |
| | #9 | |
t | |
| | #10 |
Car: 05 WRB STi-SOLD Fav Mod: Blown V8 Conversion Location: NE FL Posts: 695
IWSTI Addict since: Jul 2005 Trader Rating: (0) | Would you still be able to PM the map? I just want to look at toher peoples maps, and compair to my own. |
| | #11 | |
| Junior STI Driver | Quote:
:-\ Pro tuner on a gt35 R sti | |
| | #12 |
| Authorized Vendor Car: Your STi ;) Fav Mod: Everything Location: Atlanta Posts: 1,330
IWSTI Addict since: Mar 2005 Trader Rating: (2) | Be wary of setting DA to 0. I have been told that the ecu may be able to add to 100% of the DA, and take away up to 100% of the DA. I have never tested purposely running into negative DA, and I don't plan to. If it's true though, and you set DA to 0 and tune only with primary ignition, the car wouln't be able to pull any timing if it needed to... this could be bad. I've seen WRX's in limp mode (from broken UP cats) run more negative DA than they should have been allowed, but I don't think anybody knows much about the car when in "limp mode" (very low AM numbers). SS This ad is not endorsed by this member. Please register or login to hide this ad. |
