Old 10-02-2005, 07:29 PM   #1
Car: 2005 Silver WRX STi
Default Does anybody have a street tuner map based on stage1 93 oct?
I want a street tuner map based on the stage 1 93oct or the HWG version but with the rev limiter raised to 7,250 or 7,500 for the 05 STi. Does anybody have one, I know that with street tuner you can alter the rev limiter.
speedsnice is offline   Reply With Quote
Old 10-03-2005, 03:47 AM   #2
Moderator & ECU Tech
Fav Mod: mo boostaz
If you know that you can alter the rev limiter with StreetTUNER then why don't you just do it? Do you even have StreetTUNER? If not, then be aware that StreetTUNER maps cannot be loaded on a vehicle other than the car to which the StreetTUNER software is married. Only ProTUNER maps can be used across cars.
t
WolfPlayer is online now   Reply With Quote
Old 10-03-2005, 05:39 PM   #3
After a search I realized that I need the street tuner and cannot use street tuner maps without having the software. I will be getting street tuner after I get some more mods.
If I run the HWG map for the 93 stage 1 will it be more aggressive than the regular stage 1 map?
Old 10-04-2005, 03:24 PM   #4
Car: 04 WRB/ GOLD STI
Fav Mod: snail sticker = 5hp
As far as I can thell the difference is in the ignition timing. Both run the same amount of boost.
WRX_XB9R is offline   Reply With Quote
