Old 09-28-2005, 12:16 PM   #16
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
Originally Posted by drfrink24
Thats why an increase in WDGC and a decrease in relative boost is not making sense.
Boost leak somewhere, some how. You're loosing pressure and the ECU is trying to compensate. I would try to build a Home Depot pressure tester.
STirish is offline   Reply With Quote
Old 09-28-2005, 01:23 PM   #17
Car: JBP 04 WRX STi
Can you expand on this?
I have a compression tester, but, I don't know how I'd pressurize the system properly...
drfrink24 is offline   Reply With Quote
Old 09-28-2005, 01:35 PM   #18
It would look something like this , but you would need it to fit inside the accordion hose that connects to the MAF. You will also need a compressor with a good regulator attached. You'll want to keep pressure very constant with no spikes.
Start at a low pressure and listen for leaks, slowly up the pressure until you can hear the leak(s). I wouldn't go much above 20psi total. You will hear funny noises, such as the oil bubbling.
Old 09-28-2005, 04:46 PM   #19
Car: JBP 04 WRX STi
Well, I think I may have found it. Well, at least, confirmed what was in the pictures. I sprayed that part of the header with soapy water, and started it up.
Not only can I hear it leaking, I see bubbles form, and I can clearly smell exhaust. I would assume this could vent away at least 1-3 PSI (or more).
The thing that bothers me is I used new gaskets from subaru. Although, they were NOT the same as the old ones, they had all the dots on them. I also correctly torqued all the bolts to spec.
Hopefully, its not a warped flange.
Does anyone know how to get exact replacement metal style gaskets from subaru?
The uppipe isn't leaking, and I re-used those gaskets. I just cleaned them up with steel wool. Is this probably not a good idea for the header gaskets?
Old 02-10-2006, 01:38 PM   #20
Car: 04 Blue STi
so does this thing really work? How exactly do you hook it up?
ride_the_pony69 is offline   Reply With Quote
