Old 10-26-2006, 08:57 PM   #16
Car: 05 Subaru WRX STi
Fav Mod: Exige
I'm bringing this thread back from the dead here, but did you guys use the restrictor pill w/ the perrin ebcs? Just curious since the perrin instructions said not to. I didn't install the pill, but I'm tempted to throw it in there and see what it affects.
sti752 is offline   Reply With Quote
Old 10-27-2006, 04:52 AM   #17
Moderator & ECU Tech
Fav Mod: mo boostaz
Do not use the restrictor pill if you install the EBCS in interrupt mode (which is the mode that will give benefit).
t
Old 02-21-2007, 12:55 PM   #18
Car: 2004 Subaru WRX STi
Fav Mod: Bushings
Back from the dead...
Were you logging the Low WGDC in this log table? Is this in part, how you're able to hit target boost in every gear starting @ 3200rpm?
Thanks
Originally Posted by jays05
I've been leaning out the low end to try to get the boost to come on sooner. Realisticly it hits in the 3500 range since there aren't too many real-world applications where you lug the engine from 2k just to get the boost to hit sooner.
The responsiveness is nice. I can add/remove 0.5% in the WGDC (low) table on the top end and see a difference in the logs.
Here are my logs from the other day (what a pain it is to get the columns to line up). Two back-to-back pulls.
Code:
Time    Abs.Psi.Coolant    Dyn.Adv.Load    RPM    Timing    IDC    IAT    Knock    MAF V.    Boost    ThrottleMPH    WGDC    LM1-A/F Ratio
57:29.4    4.21    185    0    0.22    1944    24    1.25    88        1.48    -10.3    6    28    0    0.00
57:29.6    4.21    183    0    0.23    1874    24    1.20    88        1.5    -10.44    5    28    0    0.00
57:29.9    4.06    183    0    0.22    1818    24    1.17    88        1.48    -10.44    5    27    0    0.00
57:30.1    5.95    183    0    0.5    1860    29    5.95    88        2.3    -6.24    20    27    10.2    40.00
57:30.4    14.94    183    4    1.11    1843    27    11.40    88        2.46    0.44    100    27    27.06    11.95
57:30.6    15.52    183    5    1.18    1926    25.5    12.74    88        2.46    1.16    100    27    27.06    13.83
57:30.9    16.97    183    8    1.29    2048    25    14.42    88        2.56    2.47    100    26    29.41    14.10
57:31.1    17.55    183    7.5    1.37    2112    24    15.31    88        2.66    3.19    100    27    31.76    14.11
57:31.4    18.27    183    7.5    1.44    2186    23    16.80    88        2.72    3.92    100    27    34.12    13.88
57:31.6    19.14    183    7.5    1.53    2274    22.5    18.44    88        2.82    4.64    100    28    38.04    13.33
57:31.9    19.87    183    7.5    1.6    2373    22.5    19.74    88        2.86    5.37    100    28    39.22    13.14
57:32.1    20.74    183    7    1.72    2447    20.5    21.92    88        2.96    6.38    100    30    41.96    13.11
57:32.4    22.05    183    7.5    1.86    2547    18.5    25.53    88        3.12    7.69    100    30    43.53    13.13
57:32.6    23.5    183    8    2.04    2649    16    29.38    86        3.28    9.14    100    32    45.1    12.67
57:32.9    25.67    183    6    2.27    2758    14    35.90    86        3.38    11.31    100    32    46.67    12.19
57:33.1    28.14    183    6    2.51    2847    13    41.31    86        3.46    14.07    100    35    48.24    11.42
57:33.4    30.31    183    6    2.71    3019    13.5    46.37    86        3.68    16.1    100    35    50.2    11.28
57:33.6    32.2    183    6    2.84    3157    14    46.46    86        3.76    17.4    100    38    50.98    11.22
57:33.9    33.21    183    6    2.89    3306    14    53.61    86        3.74    18.27    100    38    52.55    11.33
57:34.1    33.94    183    5.5    2.95    3481    14    62.37    86        3.86    18.42    100    41    52.16    11.53
57:34.4    33.79    183    5.5    3.06    3636    14    65.93    86        4.04    18.42    100    45    51.76    11.57
57:34.6    33.65    183    6    3.04    3834    16    64.60    86        4.08    18.42    100    45    50.59    11.58
57:34.9    33.94    183    6.5    2.96    4002    17.5    64.03    86        4.04    18.42    100    48    49.8    11.41
57:35.1    33.36    183    7    2.9    4119    18    68.55    86        4.1    18.42    100    48    49.8    11.30
57:35.4    33.21    183    7    2.94    4304    19    72.52    86        4.18    18.42    100    53    50.59    11.41
57:35.6    33.21    183    7.5    2.96    4487    19.5    75.61    86        4.22    18.42    100    53    50.98    11.41
57:35.9    33.21    183    8    2.95    4629    20.5    78.00    86        4.24    18.42    100    57    51.37    11.19
57:36.1    33.21    183    8    2.95    4629    20.5    78.00    86        4.24    18.42    100    57    51.37    11.16
57:36.4    33.21    183    8    2.95    4629    20.5    78.00    86        4.24    18.42    100    57    51.37    11.10
57:36.6    32.78    183    9    2.91    5040    22    83.87    84        4.36    18.42    100    62    54.51    11.20
57:36.9    32.92    183    9.5    2.91    5191    22.5    87.47    84        4.4    18.42    100    66    56.08    11.23
57:37.1    32.78    183    9.5    2.88    5356    22.5    90.25    84        4.4    18.27    100    66    56.86    11.23
57:37.4    32.49    183    10    2.82    5490    23    89.03    84        4.42    17.84    100    70    58.43    11.29
57:37.6    32.2    183    10    2.79    5612    23    91.01    84        4.44    17.55    100    70    59.22    11.17
57:37.9    31.91    183    10    2.75    5749    23    91.98    84        4.46    17.55    100    74    60.39    11.20
57:38.1    31.76    185    8.5    2.7    5877    22    92.76    84        4.46    17.26    100    74    61.57    11.14
57:38.4    31.47    185    8.5    2.66    5976    22    93.08    84        4.46    17.11    100    78    63.14    11.13
57:38.6    31.62    185    8    2.61    6050    22    91.66    84        4.46    16.97    100    78    63.14    11.19
57:38.9    31.18    185    7.5    2.57    6161    22.5    93.34    84        4.46    16.82    100    81    64.71    11.14
57:39.1    31.18    185    7    2.55    6263    23.5    93.53    84        4.48    16.82    100    81    65.1    11.20
57:39.4    31.04    185    6.5    2.5    6403    23.5    92.90    84        4.48    16.53    100    85    66.27    11.19
57:39.6    31.18    185    4    2.43    6568    24.5    93.87    84        4.46    16.53    100    87    66.67    11.29
57:39.9    21.18    185    1    1.14    7390    27    4.74    84        3.46    0.87    17    87    0    11.25
57:40.1    3.92    185    0    0.09    6974    24    4.47    84        1.72    -10.44    10    89    0    16.11
57:40.4    3.77    185    0    0.14    6374    24    4.09    84        1.9    -10.88    10    89    0    15.21
57:40.6    3.05    187    0    0.17    5164    24    3.31    84        1.88    -11.46    10    91    0    16.35
57:40.9    3.34    187    0    0.18    4646    24    2.98    84        1.88    -11.02    10    91    0    18.64
57:41.1    3.34    187    0    0.18    4646    24    2.98    84        1.88    -11.02    10    91    0    56.14
57:41.4    3.34    187    0    0.18    4646    24    2.98    84        1.88    -11.02    10    91    0    0.00
57:41.6    3.48    187    0    0.19    4500    24    2.89    86        1.86    -10.88    10    91    0    0.00
57:41.9    3.63    187    0    0.19    4396    24    2.82    86        1.86    -10.88    10    91    0    0.00
57:42.1    3.63    187    0    0.2    4303    24    2.76    86        1.86    -10.73    10    89    0    0.00
57:42.4    3.77    187    0    0.2    4279    24    2.75    86        1.88    -10.73    10    89    0    0.00
57:42.6    3.63    187    0    0.2    4234    24    2.72    86        1.88    -10.73    10    86    0    0.00
57:42.9    3.77    187    0    0.2    4240    24    2.72    86        1.86    -10.73    10    86    0    0.00
57:43.1    3.77    187    0    0.2    4175    24    2.68    86        1.86    -10.73    10    84    0    0.00
57:43.4    3.63    187    0    0.2    4159    24    2.67    86        1.88    -10.73    10    84    0    0.00
57:43.6    3.77    187    0    0.2    4129    24    2.65    86        1.86    -10.73    10    82    0    0.00
57:43.9    3.77    187    0    0.21    4084    24    2.62    86        1.86    -10.73    10    82    0    0.00
57:44.1    3.77    189    0    0.21    4057    24    2.60    86        1.86    -10.73    10    81    0    0.00
57:44.4    3.92    189    0    0.21    3977    24    2.55    86        1.86    -10.59    10    81    0    0.00
57:44.6    3.92    189    0    0.21    3936    24    2.53    86        1.84    -10.59    10    80    0    0.00
57:44.9    3.92    189    0    0.22    3928    24    2.52    86        1.88    -10.59    10    78    0    0.00
57:45.1    3.92    189    0    0.22    3894    24    2.50    86        1.86    -10.44    10    78    0    0.00
57:45.4    3.92    189    0    0.22    3853    24    2.47    86        1.86    -10.44    10    76    0    0.00
57:45.6    3.92    189    0    0.22    3824    24    2.45    88        1.84    -10.44    10    76    0    0.00
57:45.9    4.06    189    0    0.22    3832    24    2.46    88        1.88    -10.44    10    75    0    0.00
57:46.1    3.92    189    0    0.23    3789    24    2.43    88        1.86    -10.44    10    75    0    0.00
57:46.4    4.06    187    0    0.22    3792    24    2.43    88        1.84    -10.44    10    74    0    0.00
57:46.6    4.06    187    0    0.23    3752    24    2.41    88        1.86    -10.44    10    74    0    0.00
57:46.9    4.06    187    0    0.22    3757    24    2.41    88        1.84    -10.44    10    73    0    0.00
57:47.1    4.06    187    0    0.23    3742    24    2.40    88        1.86    -10.3    10    73    0    0.00
57:47.4    4.21    187    0    0.23    3701    24    2.37    88        1.88    -10.3    10    73    0    0.00
57:47.6    4.21    187    0    0.23    3681    24    2.36    88        1.86    -10.3    10    73    0    0.00
57:47.9    4.35    187    0    0.23    3630    24    2.33    88        1.88    -10.15    10    73    0    0.00
57:48.1    4.35    187    0    0.23    3630    24    2.33    88        1.88    -10.15    10    73    0    0.00
57:48.4    4.35    187    0    0.23    3630    24    2.33    88        1.88    -10.15    10    73    0    0.00
57:48.6    4.35    187    0    0.23    3393    24    2.18    88        1.82    -10.15    9    70    0    0.00
57:48.9    4.35    187    0    0.24    3314    24    2.13    88        1.82    -10.01    9    70    0    0.00
57:49.1    4.5    187    0    0.23    3204    24    2.06    88        1.78    -10.01    9    68    0    0.00
57:49.4    4.5    187    0    0.23    3106    24    1.99    88        1.76    -10.01    9    68    0    0.00
57:49.6    4.5    187    0    0.23    3036    24    1.95    88        1.76    -10.01    9    65    0    0.00
57:49.9    4.35    187    0    0.24    2937    24    1.88    88        1.74    -10.15    9    65    0    0.00
57:50.1    4.35    187    0    0.24    2848    24    1.83    88        1.74    -10.15    9    62    0    0.00
57:50.4    4.35    185    0    0.24    2783    24    1.79    88        1.72    -10.15    8    62    0    0.00
57:50.6    4.21    185    0    0.24    2703    24    1.73    88        1.72    -10.3    8    58    0    0.00
57:50.9    4.21    185    0    0.24    2669    24    1.71    88        1.68    -10.3    8    58    0    0.00
57:51.1    4.21    185    0    0.24    2669    24    1.71    88        1.68    -10.3    8    58    0    0.00
57:51.4    4.21    185    0    0.24    2669    24    1.71    88        1.68    -10.3    8    58    0    0.00
57:51.6    4.21    185    0    0.25    2441    24    1.57    88        1.68    -10.3    8    53    0    0.00
57:51.9    12.33    185    2.5    0.88    2296    33    13.72    88        2.8    -0.73    54    53    14.51    23.89
57:52.1    5.22    185    0    0.25    3408    41    2.19    88        1.56    -9.72    7    52    0    12.98
57:52.4    3.77    185    0    0.18    3038    30    1.95    88        1.64    -10.73    7    52    0    31.80
57:52.6    3.63    185    0    0.2    2820    37    4.21    88        1.64    -10.88    8    51    8.63    35.13
57:52.9    3.77    185    -0.5    0.2    3278    24.5    4.89    88        1.74    -10.73    9    51    0    17.17
57:53.1    3.92    185    0    0.23    3417    32.5    2.19    88        1.84    -10.59    10    50    0    18.67
57:53.4    4.06    185    0    0.22    3258    24    2.09    88        1.78    -10.44    9    49    0    19.29
57:53.6    4.35    185    0    0.22    3153    24    2.02    88        1.74    -10.15    9    49    0    21.32
57:53.9    4.35    183    0    0.23    3032    24    1.95    88        1.74    -10.15    9    48    0    38.04
57:54.1    4.35    183    0    0.23    2895    24    1.86    88        1.72    -10.15    9    45    0    0.00
57:54.4    4.21    183    0    0.23    2803    24    1.80    88        1.7    -10.15    8    45    0    0.00
57:54.6    4.21    183    0    0.23    2741    24    1.76    88        1.68    -10.15    8    42    0    0.00
57:54.9    6.24    183    0    0.44    2789    17.5    8.32    88        2.28    -7.83    17    42    12.94    0.00
57:55.1    14.65    183    3    1.18    2861    23    19.53    88        2.82    0.29    100    40    42.35    30.62
57:55.4    16.24    183    5    1.38    2834    30    21.77    88        2.92    1.89    100    40    47.84    12.73
57:55.6    18.42    183    6    1.62    2910    25    26.07    88        3.1    4.21    100    39    49.02    13.17
57:55.9    21.18    183    8    1.86    2995    22.5    31.30    88        3.26    6.96    100    39    50.2    12.60
57:56.1    21.18    183    8    1.86    2995    22.5    31.30    88        3.26    6.96    100    39    50.2    12.41
57:56.4    21.18    183    8    1.86    2995    22.5    31.30    88        3.26    6.96    100    39    50.2    11.42
57:56.6    32.05    183    6    2.95    3329    14    56.81    88        3.94    17.69    100    42    52.94    11.25
57:56.9    35.1    183    5.5    3.08    3476    13.5    57.09    88        3.94    18.42    100    42    50.2    11.32
57:57.1    34.95    183    5.5    3.04    3657    14    67.11    86        3.92    18.42    100    45    49.41    11.54
57:57.4    33.36    183    6    2.98    3805    15.5    66.56    86        4.02    18.42    100    45    50.59    11.45
57:57.6    33.36    183    6.5    2.97    4015    17.5    68.52    86        4.12    18.42    100    49    49.02    11.39
57:57.9    33.36    183    7    2.92    4154    18.5    65.56    86        4.12    18.42    100    49    49.41    11.38
57:58.1    33.21    183    7    2.91    4339    19    72.21    86        4.14    18.42    100    53    50.2    11.50
57:58.4    33.07    183    7.5    2.94    4487    19.5    75.61    86        4.18    18.42    100    53    50.59    11.45
57:58.6    33.07    183    8    2.94    4611    20.5    77.70    86        4.28    18.42    100    58    50.98    11.32
57:58.9    33.21    183    8.5    2.94    4819    21.5    80.20    86        4.28    18.42    100    58    51.37    11.23
57:59.1    32.92    183    9    2.91    4918    22    81.84    86        4.32    18.27    100    62    52.94    11.23
57:59.4    32.78    183    9    2.92    5091    22    85.78    86        4.4    18.42    100    62    55.29    11.23
57:59.6    33.21    183    9.5    2.93    5272    22.5    89.98    86        4.42    18.42    100    66    55.29    11.19
57:59.9    32.63    183    9.5    2.86    5427    23    90.31    86        4.42    18.13    100    66    56.47    11.32
58:00.1    32.34    183    10    2.8    5544    23    91.06    84        4.42    17.69    100    70    58.43    11.19
58:00.4    32.05    183    10    2.75    5672    23    90.75    84        4.44    17.4    100    70    59.61    11.20
58:00.6    31.91    183    8.5    2.71    5829    21.5    92.00    84        4.44    17.26    100    74    60.39    11.22
58:00.9    31.62    183    8.5    2.66    5927    22    92.31    84        4.46    17.26    100    74    61.57    11.14
58:01.1    31.76    183    8    2.61    6084    22.5    93.44    84        4.46    17.11    100    78    61.96    11.20
58:01.4    31.76    183    8    2.61    6084    22.5    93.44    84        4.46    17.11    100    78    61.96    11.16
58:01.6    31.04    183    6.5    2.51    6342    23    93.33    84        4.48    16.53    100    81    64.31    11.20
58:01.9    31.04    183    5    2.47    6452    23.5    93.61    84        4.46    16.53    100    85    65.1    11.28
58:02.2    30.89    183    4    2.45    6599    25.5    94.31    84        4.48    16.53    100    85    65.1    11.20
58:02.4    30.89    183    3.5    2.4    6689    26    94.20    84        4.48    16.39    100    88    65.49    11.23
58:02.7    30.89    183    2.5    2.37    6747    26.5    93.56    84        4.46    16.39    100    88    65.88    11.22
58:02.9    16.1    183    0    0.92    7349    24.5    4.72    84        3.28    -2.61    15    91    0    11.28
58:03.2    4.35    183    0    0.11    6971    24    4.47    84        1.76    -10.15    10    91    0    12.57
58:03.4    3.63    185    0    0.14    6384    24    4.10    84        1.9    -10.88    10    93    0    14.97
wes.glock is offline   Reply With Quote
