Old 09-11-2005, 08:39 PM   #1
Car: 05 STi Stock
Fav Mod: ECM Prog
Default roughness monitors! log inside
I've done a search here and on other sites und I haven't found the answer. What are the roughness monitors for the cylinders? Is this knock. I have cobb Stage1 with short ram intake, and when I lift after wot I see it. I don't see it under load only when I lift. Cylinder 4 has the most at 3. log below. knock correction valus between 0 and 5.5 across range. kock sinal (digital) is 0 across below log.
help
Engine Speed(RPM) Accelerator Opening Angle(%) Ignition Timing(° BTDC) Roughness Monitor Cylinder #1() Roughness Monitor Cylinder #2() Roughness Monitor Cylinder #3() Roughness Monitor Cylinder #4()
1,602 0.0 20.0 0 0 0 0
1,567 37.1 23.0 0 0 0 0
1,919 71.9 19.0 0 0 0 0
2,032 93.0 20.0 0 0 0 0
2,385 99.6 19.0 0 0 0 0
2,554 99.6 17.0 0 0 0 0
3,040 99.6 10.5 0 0 0 0
3,297 99.6 8.0 0 0 0 0
3,903 99.6 9.0 0 0 0 0
4,177 99.6 10.0 0 0 0 0
4,657 99.6 12.0 0 0 0 0
4,912 99.6 12.5 0 0 0 0
5,473 64.1 16.5 0 1 1 3
5,603 61.7 23.0 0 1 1 3
5,266 0.0 24.0 0 1 1 3
4,810 0.0 24.0 0 1 1 3
3,409 0.0 24.0 0 1 1 3
2,880 0.0 24.0 0 1 1 3
1,925 0.0 24.0 0 1 1 3
1,436 0.0 18.0 0 1 1 3
1,100 0.0 11.0 0 1 1 3
1,118 0.0 11.0 0 1 1 3
1,050 0.0 16.5 0 1 1 3
1,016 0.0 18.0 0 1 1 3
962 0.0 19.5 0 1 1 3
944 0.0 20.5 0 1 1 3
830 0.0 22.5 0 0 0 0
759 0.0 22.5 0 0 0 0
kiomon is offline   Reply With Quote
Old 09-15-2005, 01:35 PM   #2
Car: 05 STi Stock
Fav Mod: ECM Prog
Hi Guys,
Scott (SOG) got back to me about this via PM, here was his response, in case somewhere else gets it..
The "roughness" monitors are actually from the front air fuel ratio sensor that can tell by crank position if a cylinder "misfires." If it's only on lift throttle don't worry about it. This is what can set off the misfire CEL though...
