Old 08-17-2005, 07:08 AM   #1
Fav Mod: Dyslexia
Trader Rating: (13)
Default Rescaled Map with Optimization for 05'
I have been spending ALOT of time becoming familiar with the Street Tuner over the past couple weeks trying my best to optimize Wolfplayers rescaled map for my setup, reading, logging, tweaking, reading, repeat.
What I have done so far starting from the top:
Bumped boost targets up
Bumped both wastegate Duty Cycles up
Bumped primary fuel tables a bit leaner up top
Bumped Dynamic advance A,B,C up a bit
Bumped Primary ignition up a bit
Bumped Dynamic advance to 1
I am attaching my realtime map showing the changes that I have made & would like feedback if your qualified.
As always, RUN AT YOUR OWN RISK!
Old 08-18-2005, 04:31 PM   #2
Car: 2005 STI
Fav Mod: Shawn's brain
HI...
I have been tinkering with my maps too. I have also leaned out the top end a bit but less than you did. I also bumped the primary timing across the board by .70
Are you using a wide band AFR meter? The reason I ask is I noticed your primary fuel map is quite a bit leaner than I have run to date. I am guessing your high RPM AFR could be in the range of 11.8 to perhaps 12 to 1. Am I close?
Do you have a data log you could post? I have attached a couple logs and my map for refrence.
Old 08-19-2005, 06:50 AM   #3
Fav Mod: Dyslexia
Trader Rating: (13)
I got the innovate stand alone LM-1 AFR kit. I started out very rich and it seemed to take alot to get it to 11.1:1 which is what it is running with this map.
I am at work & will post my logs when I get home tonight.
What are you running with your map?
Originally Posted by TurboQueef
HI...
Old 08-19-2005, 02:13 PM   #4
Car: 2005 STI
I have not run the map that I added timing to but with the map attached to this post, I ran 13.21 and best MPH of 102.73. Mind you... my STI seems to be slower than most.. I am not sure if it the car or track though (two other 05 STI's run much slower than I at this track). Anyway, you can check out more details in this post: 1/4 mile results with rescaled map (Thanks Wolfplayer:-)
