IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > ECU Tuning & Performance Electronics > Cobb Street Tuner
Old 08-05-2005, 06:32 AM   #1
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
Default Cooler rainy weather...
Hey guys,
There has been some kind of blanket correction with my A/F Learning since the rainy weather rolled in. The correction is there unless I'm getting into the gas (25%+ throttle) or I'm idling, after that the A/F Learning converges back to 7.8% correction. It's not surprising, but I would like to know what map(s) the correction may be coming from. This is really annoying to have weather like this when you're trying to tune
50-70 Deg F
30.3-30.5 inHg
100% Humidity
Am I the only one getting frustrated with unknown corrections?
Thanks,
Rob
STirish is offline   Reply With Quote
Old 08-05-2005, 11:06 AM   #2
We have learned so far that there is a coolant temp related fuel addition, but that is if it gets too hot I assume. It is also pretty certain than an increase in humidity creates a richer AFR due to the water displacing some of the oxygen for a given volume of air (or something like that). We also know that high IATs cause the ECU to pull timing (not related to a table I have seen I don't think). I do not know if high IATs cause extra fuel to be added since it already pulls timing because of it.
Old 08-05-2005, 12:28 PM   #3
The higher the humidity, the lower the air density, correct? The car is pulling fuel, 7.8% of it.
Ok lets keep this going, I'll add the correction tbls/maps that I know:
WG DC:
Temp Correction: Add or subtract <= ??%
Barometric Correction: Add or subtract <= 50%
Thanks for the info...
Old 08-05-2005, 12:32 PM   #4
Yeah. Increased humidity should be causing slightly richer conditions, not leaner. So if it is pulling fuel, then it must not be humidity. Where is it when it wasn't at 7.8%?
Old 08-05-2005, 01:00 PM   #5
I'd love to know exactly how much humidity affects AFR. There should be a nice and simple mathematical formula that says at X% humidity the MAF will "miscalculate" the air flow by Y%. Are we talking off by up to 0.5 AFR from 0% to 100% humidity? More? Less? The ECU is supposed to eventually correct for humidity thanks to closed loop. How fast does this happen?
Old 08-05-2005, 05:05 PM   #6
Yes, the humidity causes a rich condition in which the ECU responds to it by pulling fuel to get back to it's happy stoich during closed loop. I don't think the ECU knows of humidity, all it sees is the AFRs richening so it pulls fuel.
We have been at ~100% humidity for the last 2.5 days or so where I have seen the A/F Learning be anywhere from 7.8-9.2% which I believe is also temperature dependent because that was the only measurable parameter changing during the weather. Pressure was fairly constant.
All in all I saw a change of about 0.5 AFR to now ~46% humidity. I was seeing 9.9-10.1 and now I'm seeing 10.3-10.5. I will be doing some tuning and logging tonight so I'll further get a feel for what the ECU has done.
Old 08-05-2005, 05:30 PM   #7
Silly me. Yeah, that's what I meant to say. It's been a long day.
