Old 07-27-2005, 09:12 AM   #1
Car: JBP 04 WRX STi
IWSTI Addict since: May 2004
Default IDC over 100%
I found this searching:
(IPW + IDT)/ ((120/rpm ) x 1000) = IDC IPW = Injector Pulse width ms IDT = Injector dead time ms IDC = Injector duty cycle
Using IDT of 1.35ms
Doing some baseline logging on StreetTuner last night, and running the calculations, I'm seeing as high as 102%. This is of course, with the v1.04 basemap with NO tuning (yet ) ..
Am I doing something wrong in my calculations?
Car:
2004 STI
Snorkel Removed/Panel filter
Helix catted DP + Borla Hush
Boral coated headers
Walbro 255lph pump
drfrink24 is offline   Reply With Quote
Old 07-27-2005, 10:36 AM   #2
Moderator & ECU Tech
Fav Mod: mo boostaz
IWSTI Addict since: Jun 2004
I do my IDC calculations using the formula of IPW * RPM / 1200. I have ignored the IDT. In any case, after some boost and ignition tuning I was getting about 102% IDCs .... I guess that would be more if I included the IDT. After leaning her out a big the IDCs came down to the mid to low 90's ... and I still have more leaning out to do. However, I want to rescale the load in my tables before I lean it out anymore than I have.
I don't think you need to use IDT (IMHO). If the injectors are always open (i.e. static) then the dead time is moot and they are just open 100%. The IDT doesn't matter when the injectors are static.
t
Old 07-27-2005, 10:45 AM   #3
Fav Mod: 4th gear wheelspin
IWSTI Addict since: Nov 2004
Using the IPW * RPM / 1200 formula I have seen IDC's as high as 103 during 20psi+ boost spikes when I was tuning for the perrin EBCS. The car got plenty of fuel and did not lean out. I seem to remember reading somewhere that STI injectors can be pushed to around 110-113% before they are "static" or wide open.
Old 07-27-2005, 01:14 PM   #4
Fav Mod: mo boostaz
Scott Segal said that. Of course, I don't understand how that is even possible ... unless the reported values in the datastream don't jive with reality.
t
