Old 09-11-2008, 12:20 PM   #1
Car: Black 07 WRX STI
Fav Mod: AP
IWSTI Addict since: Feb 2007
Default 07 STI AP Stage one Problem
Hi guys. I have a 07 STI that is all stock except for the AP. I have Stage 1 1.04 map installed and the car won't let me rev past 5.5k! When I install any other map for temp reflash the car revs it out all the way with no problems! If I reinstall the same map as a temporary, the car runs fine. But when I run the car for 100 miles on any map that same problem comes back! I can't rev past 5.5k. It is like hitting a rev limiter! I called Cobb and a employee said he had no clue and he has to look into it. He never called back! I also did a reflash of the ECU and disconnected the battery but still no fix! The car has 16,000 miles on it and 99% of the time I don't wind past 3k! Can someone please help me?
STUKA is offline   Reply With Quote
Old 09-11-2008, 06:15 PM   #2
Fav Mod: AP
Default Re: 07 STI AP Stage one Problem
Anyone!?
Old 09-11-2008, 06:24 PM   #3
Car: 06 Subaru WRX STI
Fav Mod: My 20g
IWSTI Addict since: Jun 2006
Have you tried to unmarry your AP from your and then marry it back and reload the stage 1 map?
How about getting online and down loading software for the AP.
If you car works fine with other maps and not that would it is obvious that something is wrong with that map so work on replaceing that map.
Also, you unplugging you battery and all is going to do nothing because the Stage 1 map is a base map and will stay flashed to the ecu even if you disconnect the battery.
diabloadsit is offline   Reply With Quote
Old 09-11-2008, 06:37 PM   #4
Wes
I'm Jim Halpert
Fav Mod: EWG
IWSTI Addict since: Apr 2006
wait so right after you reflash it itll red past 5.5k but after exactly 100 miles itll just stop revving past 5.5K?
Wes is offline   Reply With Quote
Old 09-11-2008, 06:39 PM   #5
Car: LR 08 STI
Fav Mod: Cobb Stage 1
IWSTI Addict since: Dec 2006
Any other mods? Just for the hell of it, try adjusting your FFS and LC points up. That shouldn't be causing this but I would give it a shot....
Old 09-11-2008, 06:46 PM   #6
Wes
I'm Jim Halpert
Fav Mod: EWG
hah maybe if he had his foot on the clutch all the time it might make a difference
Old 09-12-2008, 05:08 AM   #7
Fav Mod: AP
Not exactly 100 miles but after I drive the car for a week at any map that is downloaded it won't rev past 5.5k I will try to unmarry the AP and see what happens!
Old 09-12-2008, 07:01 AM   #8
Fav Mod: My 20g
Dude this is strange. When I got protuned the last time at xxtuning. chris set me up with the base map that stays on the car even if battery dies then I have to either flash my realtime catless map on or my hi flow cat on. So I will know if something happend to the realtime map he made it so my car only revs to 3500 rpms that way I know I need to relash my realtime.
Old 09-12-2008, 08:42 PM   #9
Fav Mod: AP
Yeah I agree! I uninstalled the AP and did the whole update to the new software on the AP. I am going to drive for a week on the Stock Subaru map and go back to the Cobb and see what happens. Also the Subaru map is the newest one out!
Old 09-16-2008, 05:47 PM   #10
Car: 2007 STi LTD
Fav Mod: Stg. 2 with Knocklite
Erase that map (1.04) from your AP and your PC and download it again, maybe the map is corrupted???
BBBsti LTD is offline   Reply With Quote
Old 10-29-2008, 07:15 PM   #11
Car: 07 WRB STi
IWSTI Addict since: Aug 2008
maybe you are using the economy map. I don't think that map goes past 5500rpm.
WaLLyFnUTs is offline   Reply With Quote
Old 11-17-2008, 07:46 PM   #12
Car: 07 STI Blk
IWSTI Addict since: Feb 2008
I had a similar problem, but it was consistent with the Launch Control. Reflash WITHOUT it. And let us know what the issues are?
RayZer is offline   Reply With Quote
Old 12-08-2008, 11:21 PM   #13
IWSTI Addict since: May 2008
Are you sure its not the 2 Step Program...?
Blk07STIck is offline   Reply With Quote
