| Junior STI Driver Car: LandShark STi Fav Mod: GT40R Location: DFW Posts: 122
IWSTI Addict since: Aug 2004 Trader Rating: (0) | I've been searching here/nabisco/cobb, but haven't found any answers yet... I'm building a 2.5SB/2.0Heads hybrid motor sans AVCS. Everything I've found, the people are upgrading to STi blocks, and have WRX ECUs. I will probably be going to a standalone, unless I can find a way to run larger injectors (1600cc), but I'd like to break in the motor on ST/UTEC, and get the emissions inspection done for this year. Will the ECU freak out without the AVCS sensors? What would you have to do to make this work? Turn off the CELs? Resistor? Zero the AVCS maps? Surely, someone has done this before? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Amateur STI Driver Car: 99 Civic POS Fav Mod: Coming Soon Location: T-hizzle, NC Posts: 20
IWSTI Addict since: Nov 2007 Trader Rating: (0) | Well coming from the honda world. There are lots of block and head swaps, between vtec and non vtec. Most of the time your supposed to use the ecu that runs the head, not the block. So I would think if you used an ecu that was originally without the avcs, and tuned that. Call your tuner and ask him what ecu and tuning software you should use to pass emissions first. |
| | #3 |
IWSTI Addict since: Aug 2004 Trader Rating: (0) | I agree with you on running the ECU for the heads vs the block. Everyone I've seen who's done a hybrid setup on an STi (AVCS->non-AVCS) has gone to a standalone ECU. I plan to do the same, I just wanted one last smog check before going to the <5000mi/yr emissions exempt for $$$ registration in TX. Also, I have ST for the STi ECU, not WRX. It's not worth buying yet another ECU that will only get used once. You're right though, I will be calling my tuner. I was just curious about public opinion. Last edited by TheRipler; 07-12-2008 at 12:35 PM. |
| | #4 |
| Junior STI Driver Car: Flat4NC Fav Mod: Boost Location: On The Dyno Posts: 80
IWSTI Addict since: Dec 2006 Trader Rating: (0) | You can shut off the codes in PT so id imagine you could shut them off in st. you just have to know the P# of the codes and turn them off in the basemap. This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
