Old 05-30-2008, 01:39 AM   #1
Car: WR Blue 04 WRX STi
IWSTI Addict since: May 2008
Default Fuel economy setting
sti fans i love my sti but can not afford to drive untill i found about the cobb tuning for the ECU. The reading is about 23mpg at the least and 33 at the most for a long runs with the wind at my back on a open flat land strech. Much better than the 15-21mpg with out the cobb. I do also a qtep downpipe and a borla turbo exhaust with new NGK spark plugs so i hope that helps with the gas miles. If an one has better gas miles with there sti please do share. I have not yet tested the sti with the 93 octane fuel that the sti manual calls for just the 91 octane at the pump. oh yeah i am glad to see that the cobb is going to pay for its self what a great mod.
zen_nation is offline   Reply With Quote
Old 05-30-2008, 02:02 AM   #2
Car: 08 STi, SSM
IWSTI Addict since: Dec 2005
Default Re: Fuel economy setting
in my experience with the AP "economy" mode, prepare to be underwhelmed and disappointed. You're better off just staying out of boost and driving 60mph on the highway. IMHO none of the mods you've done will net you an appreciable increase in mileage unless your plugs were bad to begin with. Why two posts on the same thing?
Old 08-24-2008, 09:57 PM   #3
Car: Black, 04 WRX STi
IWSTI Addict since: Feb 2008
Having just made a trip using the fuel economy mode, I can say it sucks. I was throwing codes every 80 miles and only got 22mpg using a very light foot. For the return trip, I ran the stage 2 93 octane map and got 24mpg with no problems. Both runs were with A/C on.
TFocker is offline   Reply With Quote
Old 08-25-2008, 04:21 AM   #4
Car: WRB 06 WRX STI
Fav Mod: JDM Grill
IWSTI Addict since: Jul 2008
Is this OTS stage 2 map or are you protuned??? I am wondering if the accessport will help my gas mileage. I can only achieve a little more than 20 stock. Keep in mind I am in AZ and can only run 91.
WRC DNA is offline   Reply With Quote
Old 08-25-2008, 07:36 AM   #5
Car: 06 STI Steel Gray
Fav Mod: SS Stage 2+ Tune
IWSTI Addict since: Feb 2006
I believe the ECON map is a stock map with the boost tables zero'd out. If you have street tuner you may want to try using the map you normally run and zeroing out the boost tables.
warfare is offline   Reply With Quote
Old 08-25-2008, 03:48 PM   #6
It was an OTS map right from Cobb
Old 08-25-2008, 04:51 PM   #7
Car: 07 OBP STi
Fav Mod: Perrin Dual Tube
IWSTI Addict since: Jan 2008
i just did a trip on economy mode and it worked great. car was fully loaded and my combined tanks were between 24 and 28 depending on how much was highway. around town on the normal stage 2 map i can get close 24 if i drove smart.
Twsti07 is offline   Reply With Quote
