Old 03-24-2008, 03:47 PM   #1
Car: 07 Black Sti
Fav Mod: Greddy Evo 2
Send a message via AIM to snowbordr011
Default Help with map
I have been searching but I havent had much luck finding out if their is a stage 2 map that supports a cai. Any help would be appreciated! Thanks! By the way its a Aem cai
snowbordr011 is offline   Reply With Quote
Old 03-24-2008, 03:49 PM   #2
Car: 06 STI, 08 GSXR 750
Fav Mod: WC Lathe Werks Shift Knob
Default Re: Help with map
You should get a tune if you're gonna run a CAI. You can run a short ram on the OTS maps though.
Hitman83 is offline   Reply With Quote
Old 03-24-2008, 03:50 PM   #3
Car: 07 Black Sti
ok, thanks for help!
Old 03-24-2008, 03:53 PM   #4
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
I'm pretty sure that the Cobb OTS maps are only compatible with Cobb's SRI.
Old 04-21-2008, 08:15 PM   #5
Car: 04 Black STI
Send a message via AIM to reid-o Send a message via Yahoo to reid-o
Most don't post their maps here because Street Tuner's function is to allow you to change your callibration to suit your personal car and needs. For those of us with Street Tuner, we also know that, even if there were some type of base to work from, even when callibrated for a particular part, it doesn't always work out because of small differences in sensors and manufacturing.
I believe Wolfplayer has a fairly comprehensive how to on how to properly callibrate for intake offset, as he went from a stock sized MAF housing to a larger one.
Because you're not moving up in MAF housing, it shouldn't take long with some logging and excel work.
I know this thread is old, but I'm hoping this section will pick up again.
reid-o is offline   Reply With Quote
Old 04-21-2008, 08:18 PM   #6
Fav Mod: Zzyzx Coilovers
Which CAI? Some are safe to run with an OTS map, some aren't.
