Old 02-11-2008, 12:42 PM   #1
Car: 06 STI
IWSTI Addict since: Jul 2006
Default Intake Tuning
I have been logging, and I am getting two different numbers in the A/F learned column. I understand that it is because of the open loop and closed loop part of the equation. Is there a way to know which one your car is in with StreetTuner? Like where Enginuity has that is one of the logging parameters.
attila is offline   Reply With Quote
Old 02-12-2008, 08:18 AM   #2
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
IWSTI Addict since: Jul 2004
Default Re: Intake Tuning
There are actually more than two learned (LTFT) values. ST Advanced can show you the table that has four numbers depending on MAF G/S.
If you plot your learned colum vs MAF Airflow G/S then you should see the breakpoint(s).
